BT.com
Wishlist
HP HP Z Turbo Drive G2 - Solid state drive - 256 GB - internal
HP HP Z Turbo Drive G2 - Solid...
£204.49
£204.49
Add to wishlist
Delivery
Standard Due date unavailable
Super charge your productivity and creativity and deliver optimized HP Workstation workflows with the HP Z Turbo Drive G2 PCIe SSD, which delivers four times the read performance of traditional SSDs at a cost that’s remarkably similar.
Faster than HP’s fastest.
Improve the way you work and get ultra-fast I/O response to process large data sets with the second generation HP Z Turbo Drive.
Customize your solution.
Easily expand your storage solution by integrating a high-performance HP Z Turbo Drive G2 PCIe SSD with high-capacity SATA HDDs and SSDs.
Low latency technology
Realize expanded performance gains in applications that require random access with new NVMe technology.
HP Z Turbo Drive G2 - solid state drive - 256 GB - PCI Express 3.0 x4 (NVMe)
Solid state drive - internal
256 GB
NAND Flash Memory Type
Multi-level cell (MLC)
M.2
Half-height half-length form-factor
51 g
Workstation Z1 G3, Z440, Z640, Z840
256 GB
M.2
51 g
Performance
SSD Endurance
146 TB
Internal Data Rate
1.08 GBps (read) / 800 MBps (write)
4KB Random Read
120000 IOPS
4KB Random Write
60000 IOPS
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe)
Compatible Bay
M.2
Microsoft Windows 7, Windows 8
70 °C
HP Workstation Z1 G3, Z440, Z640, Z840
Scroll to top
