BT.com
Wishlist
HP HP V1910-24G SWITCH
Delivery
Standard Due date unavailable
The HP 1910 Switch Series, part of the HP OfficeConnect portfolio, delivers Fast Ethernet connectivity for cost-conscious smaller organizations. The switches are ideal for environments that require advanced features for granular control and where smart-managed flexibility is a must for easy network configuration and management. The 1910 Switch Series are advanced smart-managed fixed configuration switches in an easy-to-administer solution. Customizable features include basic layer 2 features like VLANs and link aggregation as well as advanced features such as Layer 3 static routing and ACLs.
HPE 1910-24G Switch - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x SFP
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON 2, SNMP, SNMP 3, SNMP 2c, HTTP, HTTPS
Flow control, Layer 2 switching, DHCP support, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, manageable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1ab (LLDP)
44 cm x 16 cm x 4.3 cm
3.1 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Routing Protocol
Static IP routing
Authentication Method
RADIUS
1 x ARM: 333 MHz
RAM
128 MB
Flash Memory
128 MB
24 x 1000Base-T - RJ-45 , 4 x SFP (mini-GBIC)
Rack Mounting Kit
Included
VCCI, CISPR 22 Class A, EN 61000-3-2, EN 61000-3-3, UL 60950, ICES-003 Class A, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, FCC Part 15 A
44 cm
16 cm
4.3 cm
3.1 kg
45 °C
10 - 90%
Scroll to top
