BT.com
Wishlist
HP HP EliteDisplay S240uj USB-C MNT U
HP HP EliteDisplay S240uj USB-C MNT...
£306.01
£306.01
Add to wishlist
Delivery
Standard Due date unavailable
Move into the workspace of the future with the HP EliteDisplay S240uj monitor, display with fully integrated wireless charging, and USB-C. It has premium Audio by Bang & Olufsen and QHD and looks cool from every angle with just two cables on the desk.
HP EliteDisplay S240uj Wireless Charging Monitor - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Wireless charger, USB 3.0/USB-C hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.20535 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, HDMI (MHL), DisplayPort, USB-C
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, anti-static
Silver
54.06 cm x 21.34 cm x 42.9 cm
5.5 kg
English / United Kingdom
Plug and Play, CSA, VCCI, BSMI, TUV S, WHQL, CB, CCC, FCC, ISO 9241-307, WEEE, ICES, MEPS, TUV Bauart, CECP, CEL, EAC, ISC, RCM, MSIP, SEPA, CoC, low halogen, China Energy Label Grade 1
3 years warranty
Display Type
Diagonal Size
23.8"
Viewable Size
23.8"
Built-in Devices
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.20535 mm
Pixel Per Inch
124
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
24 - 75 Hz
Horizontal Refresh Rate
24 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% colour gamut, Bang & Olufsen audio
Silver
54.06 cm x 21.34 cm x 42.9 cm - with stand
5.5 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
MHL / HDMI , DisplayPort , USB-C (DisplayPort 1.2 mode) , USB-C upstream , USB 3.0 upstream , 2 x USB 3.0 downstream , Headphones , HDMI
Mechanical
Tilt
Tilt Angle
- 5/+21
1 x Mobile High-Definition Link (MHL) cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable , 1 x USB-C cable
Backlight Life
30,000 hours
AC 120/230 V
40 Watt
Power Consumption Stand by
0.5 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 54.06 cm - depth: 21.34 cm - height: 42.9 cm - weight: 5.5 kg , Without stand - width: 54.06 cm - depth: 4.43 cm - height: 34.6 cm - weight: 3.8 kg
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
