BT.com
Wishlist
HP HP EliteDesk 705 G3 - SFF - 1 x A series A6 PRO-9500 / 3.5 G
HP HP EliteDesk 705 G3 - SFF - 1 x...
£610.41
£610.41
Add to wishlist
Delivery
Standard Due date unavailable
The HP EliteDesk 705 delivers impressive value with uncompromising performance, security, and manageability. Customize your HP EliteDesk 705 with expandable options that provide an enterprise-class experience to meet virtually any business need.
Fit user needs and the budget
Power your PC with the latest 7th generation AMD Pro A-Series APUs and upgrade your system with up to 64 GB of DDR4 memory, the latest SSD drives, graphics, and HP accessories without breaking the budget.
Security built in
IT efficiency reigns supreme when it’s backed by comprehensive security solutions, including HP BIOSphere with HP Sure Start Gen 3, AMD Secure Processor, and TPM 2.0.
Reliability for the long haul
This work-ready PC is designed with platform stability up to 18 months for a long life cycle. Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G testing.
Pure performance and enhanced visual experience
The latest AMD PRO A-Series APUs with Radeon™ graphics deliver desktop performance optimized for diverse digital workloads and dependable daily productivity across your business.
HP EliteDesk 705 G3 - A series A6 PRO-9500 3.5 GHz - 4 GB - 500 GB
Personal computer - small form factor
English / United Kingdom
1 x AMD A series A6 PRO-9500 / 3.5 GHz (3.8 GHz) (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 500 GB - SATA 6Gb/s
Graphics Controller
AMD Radeon R5
Audio Output
Stereo
GigE
OS Provided
Windows 10 Pro 64-bit Edition
38 cm x 33.8 cm x 10 cm
6.6 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty - on-site
Personal computer
Product Form Factor
Small form factor
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.8 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD B350 FCH
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
4 GB / 64 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R5
Video Interfaces
VGA, DisplayPort
HDCP compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP USB Business Slim Keyboard
USB
Mouse
Optical
USB
Ethernet Controller
Broadcom BCM5762
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x internal 2.5" x 1/8H
Slots
4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x8 mode)
4 x USB 2.0 (2 front, 2 rear) (two of them with wake functionality, one of them is fast-charging) , 4 x USB 3.1 Gen1 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.1 Gen2
ACPI, CCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
TAA Compliant
Power supply
Nominal Voltage
Power Provided
200 Watt
80 PLUS Certification
80 PLUS Platinum
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Spare Key, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP Image Assistant (free download), HP JumpStart
Limited warranty - parts and labour - 3 years - on-site
38 cm
33.8 cm
10 cm
6.6 kg
10 °C
35 °C
10 - 90% (non-condensing)
Scroll to top
