BT.com
Wishlist
HP HP AC Smart Power Adapter 65w
Delivery
Standard Due date unavailable
HP offers a broad assortment of power solutions to help you get the most out of your HP Business Notebooks, including new Smart Adapters that are both energy efficient and convenient as they can be leveraged across multiple notebook families. Smart Adapters can enhance your productivity by powering your notebook while plugged in, as well as charging your battery so that you can take your notebook with you when you unplug. HP Smart Adapters also feature integrated surge protection to protect against power fluctuations that can damage your notebook. HP Smart Adapters help you save on equipment, power consumption costs and travel weight.
HP Smart - power adapter - 65 Watt
Power adapter - external
280 g
Output Voltage
18.5 V
Power Capacity
65 Watt
10.6 cm x 4.7 cm x 2.8 cm
1 year warranty
HP 2133 Mini-Note, 2230s, 2710p, 6530b, 6730b, 6730s, 6735s; EliteBook 2730p; ProBook 4535s
Frequency Required
47 - 63 Hz
Output Voltage
18.5 V
Power Capacity
65 Watt
MTBF
200,000 hours
FCC Class B certified, CISPR 22 Class B, cUL, EN 60950, IEC950, NOM, UL 1950, EN55022 Class B
1 year warranty
Service & Support Details
Limited warranty - replacement - 1 year
20 - 80%
10.6 cm
4.7 cm
2.8 cm
280 g
HP 2133 Mini-Note ¦ HP EliteBook 2730p ¦ HP ProBook 4535s ¦ HP Compaq 2230s, 2710p, 6530b, 6730b, 6730s, 6735s
Scroll to top
