BT.com
Wishlist
HP EliteDisplay S230tm 23" 1920x1080 7ms DVI-D DisplayPort USB Touch IPS LED Monitor
Delivery
Standard Due date unavailable
Make the most of your business PC's Windows 8 environment with a fully reclining, multi-touch IPS display that puts productivity at your fingertips and keeps you comfortable throughout the day. Enjoy vibrant Full HDimages on the extra-large 58,4 cm (23') diagonal screen.
HP EliteDisplay S230tm - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Touch screen, 2 microphones, 720p webcam
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
220 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
7 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Input Connectors
DVI-D, DisplayPort
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Black, silver
59.93 cm x 6.95 cm x 40.92 cm
6.5 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, CSA, VCCI, C-Tick, BSMI, cUL, NOM, TUV S, WHQL, CB, CCC, PSB, EK, FCC, S Mark, E-Standby, CECP, TCO Displays, EAC, CEL Grade 1, ISC
Display Type
Diagonal Size
23"
Viewable Size
23"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
220 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 94 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Spanish, Dutch, Japanese
HDCP, 72% colour gamut, 5-point multi-touch, touch screen
Black, silver
59.93 cm x 6.95 cm x 40.92 cm - with stand
6.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
USB (Type B) , DVI-D (HDCP) , DisplayPort (HDCP) , Headphones
Mechanical
Tilt
Tilt Angle
+15/+70
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x DVI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m , 1 x audio cable - 1.8 m
Backlight Life
30,000 hours
Power Supply
Internal
25 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant, HP YouCam
Dimensions & Weight Details
Without stand - width: 59.93 cm - depth: 4.05 cm - height: 40.92 cm - weight: 5.5 kg , With stand - width: 59.93 cm - depth: 6.95 cm - height: 40.92 cm - weight: 6.5 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
