BT.com
Wishlist
HP EliteDisplay E271i 27" 1920x1080 7ms VGA DVI DisplayPort LED Monitor
Last Few Remaining
Clearance
Price Drop
Price Drop!
Delivery
Standard 1-3 working days
A huge screen, customizable comfort, and wide-angle IPS. IPS goes mainstream with the HP EliteDisplay E271i 68,6 cm (27') LED Backlit Monitor, a business-class combination of an extra-large screen, extra-wide viewing angles, and extraordinary comfort.
HP EliteDisplay E271i - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Silver grey
64.2 cm x 5.22 cm x 38.73 cm
4.9 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, KCC, TCO Certified Edge, KC, CECP, CEL, EPA
3 years warranty
Display Type
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 94 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Anti-glare
Silver grey
64.2 cm x 5.22 cm x 38.73 cm - without stand
4.9 kg
USB 2.0 upstream , 2 x USB 2.0 downstream , DVI-D (HDCP) , DisplayPort (HDCP) , VGA
Mechanical
Tilt Angle
-5/+30
Swivel Angle
360
Rotation Angle
90
Height Adjustment
150 mm
1 x VGA cable , 1 x DisplayPort cable , 1 x USB cable
Power Supply
Internal
35 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
Without stand - width: 64.2 cm - depth: 5.22 cm - height: 38.73 cm - weight: 4.9 kg , With stand - width: 64.2 cm - depth: 27.85 cm - height: 53.21 cm - weight: 7.7 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
