BT.com
Wishlist
HP EliteDisplay E242 LED 24" Monitor 1920x1200 7MS PLS
Delivery
Standard Due date unavailable
Be a master at multi-tasking with HP EliteDisplay E242 61 cm (24") Monitor, which delivers Full HD resolution, TCO Edge Certified comfort features, and an extra-large screen for all of your work.
HP EliteDisplay E242 - LED monitor - 24"
LED-backlit LCD monitor - 24"
USB 2.0 hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:10
Native Resolution
Full HD 1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
56.22 cm x 18.9 cm x 51.9 cm
6.23 kg
English / United Kingdom
Pricing Type
Promo
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, TCO Certified Edge, KC, CECP, CEL, EAC, ISC, SEPA
Display Type
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Pixel Per Inch
93.9
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, input select, colour temperature
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% colour gamut, Mercury free, arsenic-free glass
56.22 cm x 18.9 cm x 51.9 cm - with stand
6.23 kg
USB 2.0 upstream , 2 x USB 2.0 downstream , HDMI (HDCP) , DisplayPort (HDCP) , VGA
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
30,000 hours
Pricing Type
Promo
30 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Microsoft Windows 7, Windows 8.1, Windows 10
Dimensions & Weight Details
Without stand - width: 56.22 cm - depth: 5 cm - height: 37.74 cm - weight: 4.2 kg , With stand - width: 56.22 cm - depth: 18.9 cm - height: 51.9 cm - weight: 6.23 kg
ENERGY STAR Certified
5 °C
35 °C
20 - 80%
Scroll to top
