BT.com
Wishlist
HP EliteDisplay E232e LED monitor 23" 1920 x 1080 Full HD
Delivery
Standard Due date unavailable
Work smart and comfortably with the HP EliteDisplay E232e 58,4 cm (23") Monitor, a large-screen Full HD IPS display with Elite-class presentation features and ergonomic adjustability, available in a grey design that is compliant with Germany's BGI 650.
Put every detail on display
Enjoy sharp Full HD resolution for all your projects and collaborate easily with colleagues around the room with 178-degree viewing angles from IPS technology. The large 58,4 cm (23") diagonal screen gives you plenty of room for your open applications.
Find your perfect fit
Create the view that's right for you and boost your productivity with adjustable tilt and swivel and an impressive 150 mm height adjustment range. Use pivot rotation to customize portrait or landscape views.
Convenient connections
Connect to your choice of PC or device with HDMI, DisplayPort, VGA, and USB inputs. Keep your frequently-used devices right where you need them with USB connections at the display.
HP EliteDisplay E232e - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Pivot (rotation), swivel, tilt
Screen Coating
Anti-glare
Ergo grey
54.93 cm x 18.9 cm x 51.24 cm
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, TCO Certified Edge, KC, CECP, CEL, EAC, ISC, SEPA
Display Type
Diagonal Size
23"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
7 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% colour gamut, On-screen Digital Controls
Ergo grey
54.93 cm x 18.9 cm x 51.24 cm - with stand
2 x USB 2.0 , VGA , DisplayPort (HDCP) , HDMI (HDCP)
Mechanical
Tilt Angle
-5/+25
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable , 1 x DisplayPort cable , 1 x USB cable
28 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Display drivers, HP Display Assistant
Dimensions & Weight Details
Without stand - width: 54.93 cm - depth: 4.96 cm - height: 33.69 cm - weight: 3.63 kg
ENERGY STAR Certified
Scroll to top
