BT.com
Wishlist
HP EliteDesk 705 G2 - A series A8 PRO-8650B 3.2 GHz - 4 GB - 500 GB
HP EliteDesk 705 G2 - A series A8...
£644.25
£644.25
Add to wishlist
Delivery
Standard Due date unavailable
The HP EliteDesk 705 delivers impressive value with high-performance technology, security, and manageability. Customize your HP EliteDesk 705 with expandable options that provide enterprise-class experience to meet virtually any business need.
Pure performance and enhanced visual experience
Unlock the full potential of your PC. The latest AMD PRO A-Series APUs with AMD Radeon graphics and HP Pixel Sharp video filtering that produces sharp and color-accurate images and videos, for crystal-clear video conferencing.
Heavy security
IT efficiency reigns supreme when it's backed by a full portfolio of security solutions, including HP BIOSphere with Sure Start.
Tested to go the distance
Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G testing to help ensure reliability in the most demanding work environments.
Let nothing stand in your way
Help secure the future of your modern business. Modern PCs from HP make the most of Windows 10 to protect you from today’s security threats and maximize management and productivity features for business.
Simplify device management
Reduce the complexity of administration. DASH, Windows 10 manageability features, and HP Common Core BIOS help you easily and affordably manage assets.
Reliability for the long haul
Extend your business investments with a long life cycle and platform stability.
Multi-monitor, multi-task
Help increase productivity by up to 35% with support for up to four external Elite Displays.
Expand with ease
Extend the life of your purchase. Using the tool-less chassis this easily upgradable platform features up to four expansion slots, ten ports and multiple connectors to help you meet growing demands.
Protect your data
Help keep data safe and secure with dual storage RAID configurations, TPM and SED hard drives.
Partner with HP to help you save time and money
HP helps you preserve your time and optimize your resources with expert configuration and deployment services that bring you fast, accurate, and globally standardized IT solutions.
Green with envy
Reduce energy consumption and costs with ENERGY STAR® certified and EPEAT® Gold qualified configurations.
HP EliteDesk 705 G2 - micro tower - A8 PRO-8650B 3.2 GHz - 4 GB - 500 GB - UK layout
Personal computer - micro tower
English / United Kingdom
1 x AMD A8 PRO-8650B / 3.2 GHz (3.9 GHz) (Quad-Core)
Cache Memory
4 MB L2 Cache
Cache Per Processor
4 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD±RW (±R DL) / DVD-RAM
Graphics Controller
AMD Radeon R7
Audio Output
Stereo
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
35.5 cm x 34 cm x 17 cm
6.76 kg
3 years warranty - on-site
Personal computer
Product Form Factor
Micro tower
Built-in Devices
Solenoid hood lock, SmartCard reader
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD A78 FCH
Cache Memory
Installed Size
L2 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
4 GB / 32 GB (max)
DIMM 240-pin
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R7
Video Interfaces
VGA, DisplayPort
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Input Device
Keyboard
Keyboard
USB
Localization & Layout
Ethernet Controller
Broadcom BCM5762
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external 3.5" , 2 (total) / 1 (free) x internal 3.5"
Slots
4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x1 - full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height
6 x USB 2.0 (2 front, 4 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Power-on password, serial port I/O control, USB port control, DriveLock, HP BIOS Protection, Setup Password, BIOS Absolute Persistence, UEFI BIOS, Master Record Security, Power On Authentication, Pre-Boot Security, 1 USB 2.0 charging port
Theft/Intrusion Protection
ACPI, Energy-using Products (EuP) Lot 6, Common Criteria EAL4+
TAA Compliant
Power supply
Nominal Voltage
Power Provided
280 Watt
Efficiency
70%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Software
CyberLink Power2Go, HP Recovery Disc Creator, Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, HP PC Hardware Diagnostics UEFI, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, Drive Encryption, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Pixel Sharp, HP Driver Packs, HP CIK for Microsoft SCCM (free download)
Limited warranty - parts and labour - 3 years - on-site
35.5 cm
34 cm
17 cm
6.76 kg
10 °C
35 °C
10 - 90% (non-condensing)
Keyboards and Mice
HP EliteDesk 705 G2 - A series A8 PRO-8650B 3.2 GHz - 4...
£644.25
Wireless keyboard and mouse set
£694.24
Other bundles
£644.25
Office 365 Bundle
Save £9.99
£830.23
£644.25
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.19
£647.44
£644.25
Keep your electronic devices protected
£664.24
Scroll to top
