BT.com
Wishlist
HP DreamColour Z32X LED 31.5" Monitor 3840x2160 8MS
Delivery
Standard Due date unavailable
Go big or go home with the HP DreamColor Z32x 80,01 cm (31.5") UHD Display, HP's largest UHD 4K display, which delivers a staggering 8 million pixels and 4K resolution and has award- winning HP DreamColor technology built right in.
HP DreamColor Z32x Professional - LED monitor - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class C
Energy Consumption per Year
116 kWh
Power Consumption (On mode)
80 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort, MHL
Display Position Adjustments
Screen Coating
Anti-glare
73.71 cm x 24.55 cm x 61.38 cm
10.8 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CECP, CEL, EPA, TCO Displays 6.0, ISC, SEPA
3 years warranty
Display Type
Energy Class
Class C
116 kWh
80 W
Diagonal Size
31.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Picture in picture, picture by picture, HDCP, DreamColor, Mobile High-Definition Link (MHL), Mercury free, arsenic-free glass
73.71 cm x 24.55 cm x 61.38 cm - with stand
10.8 kg
MHL / HDMI (HDCP) , HDMI (HDCP) , DisplayPort (HDCP) , Mini DisplayPort , 4 x USB 3.0 downstream , Audio line-out , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
1 USB 3.0 fast charging port
1 x DisplayPort cable , 1 x Mini DisplayPort cable , 1 x USB cable
AC 120/230 V
80 Watt
Power Consumption Stand by
0.45 Watt
On / Off Switch
Included Software
Drivers & Utilities, HP Display Assistant
Dimensions & Weight Details
With stand - width: 73.71 cm - depth: 24.55 cm - height: 61.38 cm - weight: 10.8 kg , Without stand - width: 73.71 cm - depth: 7.01 cm - height: 43.46 cm - weight: 7.8 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
Scroll to top
