BT.com
Wishlist
HP DreamColor Z24x 24" 1920x1200 12ms DVI-D HDMI DisplayPort USB LED Monitor
HP DreamColor Z24x 24" 1920x1200...
£461.13
in stock
£461.13
Add to wishlist
Delivery
Standard Due date unavailable
Enjoy pure, consistent color accuracy from design to production with push-button color space selection and easy color calibration on the amazingly affordable HP DreamColor Z24x Display.
What's in the box
  • AC power cord
  • DisplayPort 1.2 cable
  • DVD documentation kit
  • DVI-D cable
  • Factory calibration report
  • Monitor with stand
  • USB cable
HP DreamColor Z24x Professional - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
69 kWh
Power Consumption (On mode)
47 W
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
20 ms (typical); 6 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, 2xDisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
55.94 cm x 23.8 cm x 52.5 cm
6.98 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, UL, TUV GS, VCCI, C-Tick, NOM, WHQL, CCC, PSB, FCC, RoHS, WEEE, S Mark, TCO Displays 6.0, EAC, CEL Grade 1, TUV KC
3 years warranty
Display Type
Energy Class
Class C
69 kWh
47 W
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
24 - 60 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Japanese
DreamColor, 100% sRGB colour gamut, 99% Adobe RGB colour gamut
55.94 cm x 23.8 cm x 52.5 cm - with stand
6.98 kg
DVI-D (HDCP) , DisplayPort (HDCP) , DisplayPort output (HDCP) , HDMI (HDCP) , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
120 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
Stand
1 x DisplayPort cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Power Supply
Internal
58 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 55.94 cm - depth: 6.65 cm - height: 36.5 cm - weight: 4.73 kg , With stand - width: 55.94 cm - depth: 23.8 cm - height: 52.5 cm - weight: 6.98 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
