BT.com
Wishlist
HP DIMM 16GB PC3 14900R IPL 1GX4
Delivery
Standard Due date unavailable
HP - DDR3 - 16 GB - DIMM 240-pin - 1866 MHz / PC3-14900 - CL13 - 1.5 V - registered - ECC
HPE - DDR3 - 16 GB - DIMM 240-pin
RAM memory
16 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL13
Dual rank, registered
Voltage
1.5 V
HP 715274-001
ProLiant DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special
16 GB
Upgrade Type
System specific
HP 715274-001
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL13
ECC
Chips Organization
X4
Voltage
1.5 V
HPE ProLiant DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special
Scroll to top
