BT.com
Wishlist
HP Digital Sender Flow 8500 FN1 Document Capture Workstation
Delivery
Standard Due date unavailable
Move your business beyond paper-intensive processes. Integrate with existing networked manageability and security solutions. Improve workflows by creating a virtually unlimited number of scan profiles and reliably handle up to 5,000 pages a day.
HP Digital Sender Flow 8500 fn1 Document Capture Workstation - document scanner - desktop - USB 2.0, Gigabit LAN
Document scanner - desktop
Interface Type
Scan Element Type
Flatbed: CCD / ADF: CIS
Light Source
LED
Additional Functions
Email, fax, scan to network share
Max Supported Document Size
A4 (210 x 297 mm)
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
60 ppm (mono) / 45 ppm (colour)
Max Document Size
210 mm x 297 mm
Automatic Duplexing
Supported Document Type
Plain paper, card scanner, plastic card, labels, photo
Document Feeder Type
Manual, automatic
Document Storage Capacity
100 sheets
Duty Cycle
5000 scans per day
52.07 cm x 53.34 cm x 30.81 cm
20.18 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
A4 (210 x 297 mm)
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Scan Element Type
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
45 ppm
Duty Cycle
5000 scans per day
Scanner Features
Built-in High Performance Secure Hard Disk, 8" touch screen TFT display, Ultrasonic Multi Feed Detection, built-in keyboard, Hardware Integration Pocket (HIP)
Media Handling
Max Document Size
210 mm x 297 mm
Manual, automatic
100 sheets
Gigabit LAN , USB 2.0 - Type A
CSA, C-Tick, BSMI, CISPR 22 Class A, GOST, CISPR 24, EN55024, EN55022 Class A, CB, CCC, EMC, FCC, UL 60950-1 Second Edition, KCC, CAN/CSA C22.2 No. 60950-1, IEC 60950-1 Second Edition, EN 61000-3-2:2006, EN 60950-1:2006, EN 61000-3-3:1995+A1:2001+A2:2005
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
70 Watt (24 Watt)
Software Included
I.R.I.S. OCR
52.07 cm
53.34 cm
30.81 cm
20.18 kg
Shipping Width
63 cm
Shipping Depth
60.1 cm
Shipping Height
42.8 cm
Shipping Weight
23.5 kg
10 °C
35 °C
15 - 80% (non-condensing)
Scroll to top
