BT.com
Wishlist
HP DeskJet 3634 Colour InkJet Multifunction Printer
Delivery
Standard Due date unavailable
A compact all-in-one, the HP Deskjet 3634 is designed to fit on your desk, on a shelf, or anywhere you need it. With an intuitive control panel, LCD display and user-friendly features, you can print, scan and copy with ease. Wireless direct printing enables you to connect your mobile device directly to the printer without accessing a network. Using the free HP All-in-One Printer Remote mobile app you can manage printing tasks and scan directly from smartphones and tablets. The HP Deskjet 3634 uses HP’s lowest-priced ink cartridges to deliver consistent, high-quality results. It also features a quiet mode for noise-sensitive environments and delivers borderless printing up to A4 size.
HP Deskjet 3634 All-in-One - multifunction printer (colour)
Multifunction printer
English / United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
100 - 250 pages
Max Copying Speed
Up to 5 ppm (mono) / up to 3.5 ppm (colour)
Max Copying Resolution
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
Max Printing Speed
Up to 20 ppm (mono) / up to 16 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
60 sheets
Output Trays Capacity
25 sheets
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
HP Auto Wireless Connect, automatic paper sensor, Mobile Printing
AC 120/230 V (50/60Hz)
43.8 cm x 31 cm x 15.8 cm
4.17 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
1000 pages
100 - 250 pages
Display Features
7 segment LCD display with icons
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Copying
Max Copying Speed
Max Document Enlargement
200%
Max Document Reduction
25%
Maximum Copies
9
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
328 nozzles (black), 588 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI, PCLm, URF
First Print Out Time B/W
14 sec
First Print Out Time Colour
17 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 76 x 127 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
60 sheets
25 sheets
Input tray - 60 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
Speed Details
Printing: up to 8.5 ppm - B/W (ISO) , Printing: up to 20 ppm (Letter A) - B/W draft , Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 6 ppm - colour (ISO) , Printing: up to 16 ppm (Letter A) - colour draft , Printing: up to 16 ppm (A4) - colour draft , Copying: up to 5 ppm (A4) - B/W (ISO) , Copying: up to 3.5 ppm (A4) - colour (ISO)
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10
Software Included
Drivers & Utilities, HP Photo Creations
10 Watt
Power Consumption Standby
2.1 Watt
Power Consumption Sleep
0.88 Watt
USB cable
Consumables Included
1 x Cartridge (black) - up to 190 pages - HP 63 , 1 x Cartridge (tricolour) - up to 165 pages - HP 63
GOST, Directive 1999/5/EC, KCC, FCC CFR47 Part 15 B, VCCI V-2, EN 61000-3-3:2008, NOM-019-SCFI-1993 IRAM, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60950-1:2006, ICES-003 issue 5 Class B, GB4943.1-2011, CNS13438:2006, CNS 14336, LVD 2006/95/EC, IEC 60950-1:2005 Second Edition, CISPR 24:2010, EN55022:2010 Class B, EN 55024:2010, CISPR 22:2008
ENERGY STAR Certified
43.8 cm
31 cm
15.8 cm
4.17 kg
Shipping Width
47.5 cm
Shipping Depth
19.2 cm
Shipping Height
35.4 cm
Shipping Weight
5.09 kg
Sound Emission
47 dBA (operating)
5 °C
15 - 80% (non-condensing)
Scroll to top
