BT.com
Wishlist
HP Deskjet 3055A e-All-in-One - printer / copier / scanner - colour
Delivery
Standard Due date unavailable
Print, scan and copy easily, plus print documents, web pages and homework wirelessly. Designed to deliver fast, dependable performance, this affordable all-in-one increases what you can do at home, and can help you conserve resources. Get high-quality results with laser-quality text and vivid colour graphics. Up to 4800 x 1200 optimised dpi colour. Get started straightaway. The Deskjet 3055A is easy-to-use and installs out of the box in just a few minutes. It connects automatically to your home network thanks to HP Auto Wireless Connect.
HP Deskjet 3055A e-All-in-One J611n - multifunction printer (colour)
Printer / copier / scanner
Copier Type
Digital
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 impressions
Recommended Monthly Volume
250 - 500 pages
Max Copying Speed
Up to 4.5 ppm (mono) / up to 2.5 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 5.5 ppm (mono) / up to 4 ppm (colour)
Max Printing Resolution
Up to 600 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, photo paper
Standard Media Capacity
60 sheets
Output Trays Capacity
25 sheets
PC Connection Availability
PC Connection
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
HP ePrint
AC 110/230 V (50/60Hz)
42.7 cm x 40.6 cm x 24.9 cm
3.6 kg
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Ink-jet - colour
1000 impressions
250 - 500 pages
PC Connection
USB 2.0, Wi-Fi(n)
AirPrint Enabled
HP ePrint
Copying
Max Copying Speed
Maximum Copies
20
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Max Media Size
A4
Min Media Weight
75 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
Supported Envelope Sizes
International DL (110 x 220 mm)
60 sheets
25 sheets
Input tray - 60 sheets - A4 (210 x 297 mm) , Output tray - 25 sheets - A4 (210 x 297 mm)
Speed Details
Printing: up to 5.5 ppm - B/W (ISO) , Printing: up to 4 ppm - colour (ISO) , Copying: up to 4.5 ppm - B/W (ISO) , Copying: up to 2.5 ppm - colour (ISO)
1 x USB 2.0
Operating System Support
MS Windows XP SP2 or later, Apple Mac OS X 10.5, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6
Software Included
Drivers & Utilities, HP Photo Creations
9 Watt
Power Consumption Standby
2.5 Watt
Power Consumption Sleep
1.2 Watt
USB cable
ENERGY STAR Certified
42.7 cm
40.6 cm
24.9 cm
3.6 kg
Shipping Weight
5.22 kg
5 °C
15 - 80%
Accessories
£14.85
Scroll to top
