BT.com
Wishlist
HP Deskjet 2510 All-in-One - printer / copier / scanner - colour
Delivery
Standard Due date unavailable
You can count on affordable and reliable performance from the HP Deskjet 2510 all-in-one. Copy and scan quickly and easily using the improved graphic display. Print borderless photos and enjoy impressive results with Original HP ink cartridges, while saving energy with this ENERGY STAR qualified product.
HP Deskjet 2510 All-in-One - multifunction printer ( colour )
Printer / copier / scanner
Copier Type
Digital
Printing Technology
Ink-jet ( colour )
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 impressions
Recommended Monthly Volume
300 - 400 pages
Max Copying Speed
Up to 5 ppm (mono) / up to 3 ppm (colour)
Max Copying Resolution
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
Max Printing Speed
Up to 7.5 ppm (mono) / up to 4.5 ppm (colour)
Max Printing Resolution
Up to 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Display
1.1"
Original Size
216 x 297 mm (max)
Media Size
A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, greeting cards, photo paper
Standard Media Capacity
60 sheets
Output Trays Capacity
25 sheets
PC Connection Availability
PC Connection
USB 2.0
AC 110/230 V ( 50/60Hz )
43.14 cm x 43.89 cm x 25.16 cm
3.9 kg
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Ink-jet - colour
1000 impressions
300 - 400 pages
Display Diagonal Size
1.1"
PC Connection
USB 2.0
Copying
Max Copying Speed
Maximum Copies
10
Copying Features
Fit to page
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Document & Media Handling
Max Original Size
216 x 297 mm
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 216 x 297 mm
Supported Envelope Sizes
International DL (110 x 220 mm)
Borderless Photo Sizes
216 x 297 mm
60 sheets
25 sheets
Input tray - 60 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
Speed Details
Printing: up to 7.5 ppm - B/W normal , Printing: up to 4.5 ppm - colour normal , Printing: up to 7.5 ppm - B/W (ISO) , Printing: up to 4.5 ppm - colour (ISO) , Copying: up to 5 ppm - B/W (ISO) , Copying: up to 3 ppm - B/W (ISO)
1 x USB 2.0
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6, Apple Mac OS X 10.7
Software Included
Drivers & Utilities, HP Photo Creations
10 Watt
Power Consumption Standby
2.3 Watt
Power Consumption Sleep
1.3 Watt
43.14 cm
43.89 cm
25.16 cm
3.9 kg
Scroll to top
