BT.com
Wishlist
HP DeskJet 2134 Colour InkJet Multifunction Printer
Delivery
Standard Due date unavailable
Make your everyday printing, copying, and scanning easy with the HP DeskJet 2134 All-in-One. With a space-saving design, this compact printer can fit on your desk, on a shelf, or anywhere you need it. It uses HP’s lowest-priced ink cartridges to deliver consistent, high-quality results, and meets ENERGY STAR requirements to save you energy and money
HP Deskjet 2134 All-in-One - multifunction printer (colour)
Multifunction printer
English / United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
50 - 200 pages
Max Copying Speed
Up to 5 ppm (mono) / up to 3 ppm (colour)
Max Copying Resolution
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
Max Printing Speed
Up to 20 ppm (mono) / up to 16 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
60 sheets
Max Media Capacity
60 sheets
Output Trays Capacity
25 sheets
Connection Availability
USB 2.0
AC 120/230 V (50/60Hz)
42.5 cm x 30.4 cm x 14.9 cm
3.42 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
1000 pages
50 - 200 pages
USB 2.0
Copying
Max Copying Speed
Maximum Copies
9
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
328 nozzles (black), 588 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
First Print Out Time B/W
15 sec
First Print Out Time Colour
18 sec
Colour Management Features
ColorLok Technology
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 101.6 x 152.4 mm, 89 x 127 mm, 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215 x 279 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm)
60 sheets
Max Media Capacity
60 sheets
25 sheets
Input tray size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
Speed Details
Printing: up to 20 ppm (Letter A) - B/W draft , Printing: up to 16 ppm (Letter A) - colour draft , Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 16 ppm (A4) - colour draft , Printing: up to 7.5 ppm (Letter A) - B/W (ISO) , Printing: up to 5.5 ppm (Letter A) - colour (ISO) , Printing: up to 7.5 ppm (A4) - B/W (ISO) , Printing: up to 5.5 ppm (A4) - colour (ISO) , Printing: up to 16 ppm (10 x 15 cm (4"x6")) - photo draft , Printing: 66 sec (10 x 15 cm (4"x6")) - photo normal , Copying: up to 5 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO)
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows XP SP3, Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits)
Software Included
Drivers & Utilities
10 Watt
Power Consumption Standby
1.9 Watt
Power Consumption Sleep
0.9 Watt
Consumables Included
1 x Cartridge (black) - up to 190 pages - HP 63 , 1 x Cartridge (yellow/cyan/magenta) - up to 165 pages - HP 63
FCC Class B certified, BSMI, CCC, FCC CFR47 Part 15, KCC, VCCI V-2, EN 61000-3-3:2008, ICES-003 issue 4 Class B, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60950-1:2006, EAC, EN 62479:2010, GB4943.1-2011, CNS 14336, CNS 13438, LVD 2006/95/EC, IEC 60950-1:2005 Second Edition, CISPR 24:2010, EN55022:2010 Class B, EN 55024:2010, CISPR 22:2008, NOM-019-SCFI-1993
ENERGY STAR Certified
42.5 cm
30.4 cm
14.9 cm
3.42 kg
Shipping Width
47.5 cm
Shipping Depth
19.1 cm
Shipping Height
35.4 cm
Shipping Weight
4.48 kg
Sound Emission
48 dBA (operating)
5 °C
15 - 80% (non-condensing)
Scroll to top
