BT.com
Wishlist
HP Deskjet 1050A All-in-One - multifunction ( printer / copier / scanner ) ( colour )
Delivery
Standard Due date unavailable
HP Deskjet 1050A All-in-One Drucker
Print everyday documents plus scan and copy quickly and affordably with this compact, reliable HP all-in-one. Easy to set up and use, the compact design fits your taste, space and budget. Low-cost HP supplies make it a practical choice. Reduce your environmental impact with an all-in-one that is made, in part, from recycled materials and uses less energy than its predecessor.
ENERGY STAR® qualified
- Low energy: sleep mode is comparable with powering a clock radio.
- Recycle or reuse 99% of this packaging - including a reusable bag.
- Original HP cartridges contain up to 70% recycled plastic.
Print, scan and copy with one compact, affordable and easy-to-use device.
- Do it all - print, scan and copy at home with this affordable, easy-to-use all-in-one.
- Compact, space-saving design and attractive styling mean it can be used in any room.
- Get high-quality results whatever you print or copy - ideal for everyday documents.
- Get started straightaway - simple to set up and installs right out of the box in just a few minutes.
- No waiting around - this versatile all-in-one powers up in seconds.
Enjoy reliable, affordable performance from the world's top-selling printer brand
- Be sure of reliable, affordable performance with HP Deskjet - celebrating more than 20 years as the world's top-selling printer brand.
- Print more pages with optional high-capacity ink cartridges.
- Get peace of mind with the one-year limited warranty plus HP Total Care advice and support.
Reduce energy consumption and conserve resources - designed with the environment in mind.
- Conserve energy with this ENERGY STAR® qualified all-in-one.
- Save money and resources - low-consumption design cuts energy use in half compared with previous products.
- Easily recycle HP Deskjet packaging - this product is shipped in 99% recyclable packaging.
- Get free, easy recycling - cartridges returned through HP Planet Partners4 are recycled responsibly
HP Deskjet 1050A All-in-One J410g - multifunction printer (colour)
Printer / copier / scanner
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet
Monthly Duty Cycle (max)
1000 impressions
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 16 ppm (mono) / up to 12 ppm (colour)
Max Printing Resolution
Up to 600 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, iron-on transfers, photo paper
Standard Media Capacity
60 sheets
Output Trays Capacity
25 sheets
PC Connection Availability
PC Connection
USB 2.0
AC 110/230 V (50/60Hz)
42.7 cm x 40.6 cm x 24.9 cm
3.6 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
1000 impressions
PC Connection
USB 2.0
Copying
Maximum Copies
10
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Printer Drivers / Emulations
PCL 3 GUI
Scanning
Optical Resolution
1200 dpi
Colour Depth
24 bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Max Media Size
A4
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
60 sheets
25 sheets
Input tray - 60 sheets - A4 (210 x 297 mm)
Speed Details
Printing: up to 16 ppm (A4) - B/W draft , Printing: up to 12 ppm (A4) - colour text and graphics draft
1 x USB 2.0
Operating System Support
MS Windows XP SP2 or later, Apple Mac OS X 10.5, MS Windows 7, Apple Mac OS X 10.6.x, MS Windows Vista
10 Watt
Power Consumption Standby
2.4 Watt
Power Consumption Sleep
1.28 Watt
42.7 cm
40.6 cm
24.9 cm
3.6 kg
Shipping Weight
5.2 kg
45 °C
Accessories
£25.04
HP 301XL Black Ink Cartridge Twin Pack
Quicklinx: 9BL5 | In Stock
£47.07
£47.98
Scroll to top
