BT.com
Wishlist
HP CPQ LA2306X 23", LED LCD MONITOR, 1920 x 1080
Delivery
Standard Due date unavailable
The Advantage Series HP Compaq LA2306x's slender, yet expansive 58,4 cm (23") diagonal LCD monitor enables advanced adjustability for increased productivity, while LED technology helps improve recyclability and Full HD helps improve image quality.
HP Compaq LA2306x - LED monitor - 23"
LED-backlit LCD monitor - 23"
USB Hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 1000000:1 (dynamic)
Response Time
5 ms
Colour Support
16 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, anti-static
55.2 cm x 24.9 cm x 35.1 cm
6.8 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, TUV, VCCI, C-Tick, BSMI, GOST, NOM, WHQL, CCC, FCC, RoHS, ETL, TCO Displays 5.0, KCC, WEEE, E-Standby, China Energy Label Level 1, KC
3 years warranty
Display Type
Diagonal Size
23"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
16 million colours
Response Time
5 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
94 kHz
Video Bandwidth
200 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
AssetControl, 68% colour gamut
55.2 cm x 24.9 cm x 35.1 cm - with stand
6.8 kg
VGA , DisplayPort , DVI-D , USB upstream (Type B) , 2 x USB downstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
360
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Wall mountable
1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
30,000 hours
33 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
HP Display Assistant, PDF Complete
Dimensions & Weight Details
With stand - width: 55.2 cm - depth: 24.9 cm - height: 35.1 cm - weight: 6.8 kg , Without stand - width: 55.5 cm - depth: 5 cm - height: 33.4 cm - weight: 4.1 kg
EPEAT Compliant
EPEAT Gold
Limited warranty - parts and labour - 3 years - on-site , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
