BT.com
Wishlist
HP Compaq LA2006x 20" LED Backlit LCD Monitor, 1600 x 900
Delivery
Standard Due date unavailable
The Advantage Series HP Compaq LA2006x offers a super-slim, soft black, modern design with a 50,8 cm (20") diagonal LED Backlit LCD panel that can help improve recyclability and durability, while the slider stand can help enhance comfort adjustability.
HP Compaq LA2006x - LED monitor - 20"
LED-backlit LCD monitor - 20"
USB Hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 1000000:1 (dynamic)
Response Time
5 ms
Colour Support
16 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
48.4 cm x 21.1 cm x 31.6 cm
5.5 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, TUV, VCCI, C-Tick, BSMI, GOST, NOM, WHQL, CCC, FCC, RoHS, ETL, KCC, WEEE, TCO '05, E-Standby, China Energy Label Level 1
3 years warranty
Display Type
Diagonal Size
20"
Viewable Size
20.0"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
16 million colours
Response Time
5 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
83 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
Controls & Adjustments
Brightness, contrast, colour temperature, phase, clock
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 68% colour gamut
48.4 cm x 21.1 cm x 31.6 cm - with stand
5.5 kg
VGA , DisplayPort , DVI-D , USB
Mechanical
Tilt Angle
35
Swivel Angle
360
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x USB cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m
Backlight Life
30,000 hours
26 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
HP Display Assistant, PDF Complete
Dimensions & Weight Details
Without stand - width: 48.4 cm - depth: 4.8 cm - height: 29.6 cm - weight: 3.4 kg , With stand - width: 48.4 cm - depth: 21.1 cm - height: 31.6 cm - weight: 5.5 kg
EPEAT Compliant
EPEAT Gold
Limited warranty - parts and labour - 3 years - on-site
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
