BT.com
Wishlist
HP Colour LaserJet CM6040f Colour Laser Multifunction Printer
Delivery
Standard Due date unavailable
HP Color LaserJet CM6040 MFP
See productivity soar with this high performing Color LaserJet MFP. Create A3 colour documents with excellent line and image quality. Enjoy fast print speeds; print, copy, scan, fax and digital sending functionality plus exceptional ease of use.
HP Color LaserJet CM6040f MFP - multifunction printer ( colour )
Fax / copier / printer / scanner
Fax Type
Plain paper
Printing Technology
Laser ( colour )
Monthly Duty Cycle (max)
220000 impressions
Max Copying Speed
Up to 40 ppm (mono) / up to 40 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi
Scanning
600 dpi
Original Size
A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
2100 sheets
Max Media Capacity
2100 sheets
Output Trays Capacity
500 sheets
Stacker
Optional
Stapler
Optional
Automatic Duplexing
Yes (copying)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
AC 230 V ( 50Hz )
70.4 cm x 63.5 cm x 119.4 cm
144.9 kg
Microsoft Certification
Works with Windows Vista
Environmental Standards
ENERGY STAR Qualified , EPEAT Bronze
Fax Type
Plain paper
Printing Technology
Laser - colour
220000 impressions
PC Connection
Standard Memory
512 MB
Max Supported Memory
1 GB
Hard Disk Drive
80 GB
Copying
Max Copying Speed
Max Document Enlargement
200%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c
Scanning
Optical Resolution
600 dpi
Grey Scale Depth
8 bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi
Fax Machine Features
Broadcast Transmission
100 stations
Automatic redialing
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A3/Ledger
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
2100 sheets
Max Media Capacity
2100 sheets
500 sheets
ADF - 50 sheets , 4 x input tray - 250 sheets , Input tray - 500 sheets , Input tray - 100 sheets
Finishing Equipment
Stacker
Optional
Stapler
Optional
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows Server 2003, Apple Mac OS X 10.3, Apple Mac OS X 10.2.8, Apple MacOS X 10.4 or later, MS Windows Vista
AC 230 V ( 50Hz )
920 Watt
Power Consumption Standby
230 Watt
Power Consumption Sleep
24.5 Watt
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
EPEAT Compliant
EPEAT Bronze
70.4 cm
63.5 cm
119.4 cm
144.9 kg
15 °C
27 °C
Accessories
HP 824A Black LaserJet Image Drum
Quicklinx: 67DR | In Stock
£63.32
£286.39
£285.16
£285.16
HP Colour LaserJet CB458A 220V Fuser Kit
Quicklinx: 6D7S | In Stock
£128.30
HP 824A Cyan LaserJet Image Drum
Quicklinx: 6LYS | In Stock
£178.00
HP 824A Yellow LaserJet Image Drum
Quicklinx: 6LYV | In Stock
£178.00
HP 824A Magenta LaserJet Image Drum
Quicklinx: 6LYX | In Stock
£178.00
Scroll to top
