BT.com
Wishlist
HP Color LaserJet Pro M277n Multifunction Printer
Get more pages, performance and protection.
Delivery
Standard Due date unavailable
You'd never expect this much performance from such a small package. This loaded MFP and Original HP Toner cartridges with JetIntelligence combine to give you the tools you need to get the job done.
HP Color LaserJet Pro MFP M277n - multifunction printer (colour)
Fax / copier / printer / scanner
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 2500 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 18 ppm (colour)
Max Copying Resolution
Up to 300 x 420 dpi (mono) / up to 300 x 420 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 203 x 96 dpi, 203 x 192 dpi
Scanning
1200 x 1200 dpi
Display
3"
Original Size
101.6 x 152.4 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, greeting cards, photo paper
Standard Media Capacity
150 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, HP ePrint, scan to Cloud, Instant-on Technology, Mopria certified
AC 230 V (50Hz)
42 cm x 38.4 cm x 32.2 cm
15.3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - colour
30000 pages
250 - 2500 pages
Display Diagonal Size
3"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
256 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Fit to page, ID Card Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, PCLm
Image Enhancement Technology
HP ImageREt 3600
First Print Out Time B/W
11.5 sec
First Print Out Time Colour
13 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
30-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 400 pages
PC Faxing
Yes (send only)
Fax Machine Features
Speed Dialing
100 station(s)
Broadcast Transmission
119 stations
Delayed Transmission
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), poll receive
Document & Media Handling
Min Original Size
101.6 x 152.4 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
52 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 101.6 x 152.4 mm, B6 (125 x 176 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
150 sheets
1 sheet
100 sheets
Bypass tray - 1 sheet , Input tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 52 g/m² - 220 g/m² , ADF - 50 sheets size: 101.6 x 152.4 mm - Legal (216 x 356 mm) weight: 60 g/m² - 90 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 18 ppm (A4) - B/W normal , Printing: up to 18 ppm (A4) - colour normal , Printing: up to 19 ppm (Letter A) - B/W normal , Printing: up to 19 ppm (Letter A) - colour normal , Copying: up to 18 ppm (A4) - B/W normal , Copying: up to 18 ppm (A4) - colour normal , Copying: up to 19 ppm (Letter A) - B/W normal , Copying: up to 19 ppm (Letter A) - colour normal , Scanning: up to 21 ppm (A4) - B/W normal , Scanning: up to 14 ppm (A4) - colour normal , Scanning: up to 21 ppm (Letter A) - B/W normal , Scanning: up to 14 ppm (Letter A) - colour normal
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
Operating System Support
Sun Solaris 8, MS Windows XP SP3, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows XP 64-bit Edition, SuSe Linux 10.3, HP-UX 11.0, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, Oracle Solaris 9, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, Android, iOS, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Linux 9.4, Linux 9.5, Ubuntu Linux 8.04.1, Ubuntu Linux 8.04.2, Windows RT 8, Windows 8 Pro, Windows 8 Pro 64-bit, Windows 8 Enterprise, Windows 8 Enterprise 64-bit, Windows 8 Enterprise N, Windows 8 Enterprise N 64-bit
Software Included
Drivers & Utilities
AC 230 V (50Hz)
365 Watt
Power Consumption Standby
10.5 Watt
Power Consumption Sleep
2.7 Watt
First Copy Out Time B/W
13.5 sec
First Copy Out Time Colour
16 sec
USB cable
Consumables Included
1 x Cartridge (black) - up to 1500 pages , 1 x Cartridge (cyan) - up to 700 pages , 1 x Cartridge (magenta) - up to 700 pages , 1 x Cartridge (yellow) - up to 700 pages
FCC Class B certified, CISPR 22 Class B, Laser Class 1, FCC CFR47 Part 15, TBR21, EN 60825-1, CECP, EN 61000-3-3:2008, CSA C22.2 No. 60950-1-07 Second Edition, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, ICES-003 issue 5 Class B, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 62479:2010, EN55024:2010, IEC60950-1:2005+A1:2009, EN55022:2010 Class B
ENERGY STAR Certified
42 cm
38.4 cm
32.2 cm
15.3 kg
Shipping Width
49.8 cm
Shipping Depth
49 cm
Shipping Height
39.8 cm
Shipping Weight
20.2 kg
Sound Emission
50 dBA (operating)
15 °C
30 °C
10 - 80% (non-condensing)
Accessories
HP 201A Black Original Toner Cartridge
Quicklinx: B6R9 | In Stock
£61.70
HP 201A Cyan Original Toner Cartridge
Quicklinx: B6RB | In Stock
£70.15
HP 201A Yellow Original Toner Cartridge
Quicklinx: B6RC | In Stock
£70.15
HP 201A Magenta Original Toner Cartridge
Quicklinx: B6RF | In Stock
£70.15
£79.87
£88.58
£88.58
£88.58
Scroll to top
