BT.com
Wishlist
HP Color LaserJet Enterprise CM4540fskm Colour Laser Multifunction Printer
HP Color LaserJet Enterprise...
£4,094.97
£4,094.97
Add to wishlist
Delivery
Standard Due date unavailable
HP Color LaserJet Enterprise CM4540 MFP
Workgroups can easily print, copy, scan, digitally send and fax with this intuitive colour MFP series. Brilliant colour plus robust paper handling, management, security and extensibility features make this MFP a productivity powerhouse.
HP LaserJet Enterprise CM4540fskm MFP - multifunction printer (colour)
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
175000 impressions
Recommended Monthly Volume
5000 - 9000 pages
Max Copying Speed
Up to 40 ppm (mono) / up to 40 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
JBIG
Scanning
600 x 600 dpi
Display
8.1"
Original Size
76 x 137 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper
Standard Media Capacity
2100 sheets
Output Trays Capacity
900 sheets
Stacker
Included
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail
AC 230 V (50Hz)
107 cm x 66.8 cm x 112 cm
88.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, EPEAT Silver
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
175000 impressions
5000 - 9000 pages
Display Diagonal Size
8.1"
Display Features
Touch screen
PC Connection
Standard Memory
1.28 GB
Max Supported Memory
1.28 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
Scanning
Optical Resolution
600 x 600 dpi
Colour Depth
30-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
JBIG
Fax Machine Features
Speed Dialing
100 station(s)
Broadcast Transmission
100 stations
Fax forwarding, automatic redialing
Document & Media Handling
Min Original Size
76 x 137 mm
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
2100 sheets
900 sheets
ADF - 50 sheets , Output tray - 900 sheets , 4 x input tray - 500 sheets - Legal (216 x 356 mm) , Input tray - 100 sheets
Speed Details
Printing: up to 40 ppm (A4) - B/W , Printing: up to 40 ppm (A4) - colour , Copying: up to 40 ppm (A4) - colour , Copying: up to 40 ppm (A4) - B/W
Finishing Equipment
Stacker
Included
Stapler
Included
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Operating System Support
MS Windows Server 2003, MS Windows XP SP2 or later, Apple MacOS X 10.4 or later, MS Windows Vista, MS Windows Server 2008
Software Included
Drivers & Utilities
AC 230 V (50Hz)
850 Watt
Power Consumption Standby
91 Watt
Power Consumption Sleep
21.5 Watt
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
FCC Class A certified, UL, cUL, EN 61000-3-2, GS, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, EMC, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
107 cm
66.8 cm
112 cm
88.6 kg
Shipping Weight
111.4 kg
Sound Emission
57 dBA (operating)
10 °C
30 °C
10 - 80%
Accessories
Ink
£142.93
£186.22
£232.59
£231.76
Other bundles
HP Colour LaserJet CE247A 220V Fuser Kit
Quicklinx: 7HH0 | In Stock
£182.56
Scroll to top
