BT.com
Wishlist
HP Color LaserJet CM6030 Colour Laser Multifunction Printer
Delivery
Standard Due date unavailable
HP Colour Laserjet CM6030 MFP
See productivity soar with this high performing Color LaserJet MFP. Create A3 colour documents with excellent line and image quality. Enjoy fast print speeds; print, copy, scan, fax and digital sending functionality plus exceptional ease of use.
HP Color LaserJet CM6030 MFP - multifunction printer ( colour )
Printer / copier / scanner
Copier Type
Digital
Printing Technology
Laser ( colour )
Monthly Duty Cycle (max)
200000 impressions
Recommended Monthly Volume
5000 - 10000 pages
Max Copying Speed
Up to 31 ppm (mono) / up to 31 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 40 ppm (mono) / up to 40 ppm (colour)
Max Printing Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 1200 dpi (colour)
Scanning
600 dpi
Original Size
A3 (297 x 420 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
1100 sheets
Max Media Capacity
1100 sheets
Output Trays Capacity
500 sheets
Stacker
Optional
Stapler
Optional
Automatic Duplexing
Yes (copying)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN
70.4 cm x 67.3 cm x 98.8 cm
139.9 kg
Microsoft Certification
Works with Windows Vista
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Laser - colour
200000 impressions
5000 - 10000 pages
PC Connection
Standard Memory
512 MB
Max Supported Memory
1 GB
Hard Disk Drive
80 GB
Copying
Max Copying Speed
Max Document Enlargement
200%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3
Image Enhancement Technology
HP ImageREt 4800
Scanning
Optical Resolution
600 dpi
Grey Scale Depth
8 bit
Document & Media Handling
Max Original Size
A3 (297 x 420 mm)
Original Type
Sheets
50 sheets
Max Media Size
A3
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
1100 sheets
Max Media Capacity
1100 sheets
500 sheets
ADF - 50 sheets , Input tray - 100 sheets , 2 x input tray - 500 sheets
Finishing Equipment
Stacker
Optional
Stapler
Optional
1 x USB 2.0 , 1 x Gigabit LAN
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows Server 2003, Apple Mac OS X 10.3, Apple Mac OS X 10.2.8, Apple MacOS X 10.4 or later, MS Windows Vista
1070 Watt
Power Consumption Sleep
23 Watt
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
70.4 cm
67.3 cm
98.8 cm
139.9 kg
15 °C
27 °C
30 - 70%
Accessories
£55.99
HP 824A Black LaserJet Image Drum
Quicklinx: 67DR | In Stock
£72.64
£320.72
£315.43
£315.43
HP 824A Cyan LaserJet Image Drum
Quicklinx: 6LYS | In Stock
£194.42
HP 824A Yellow LaserJet Image Drum
Quicklinx: 6LYV | In Stock
£194.42
HP 824A Magenta LaserJet Image Drum
Quicklinx: 6LYX | In Stock
£194.42
Scroll to top
