BT.com
Wishlist
HP Chromebook 11 N3060 4GB/16GB
Delivery
Standard Due date unavailable
Inspire learning and help elevate productivity to the next level with HP Chromebook 11. Affordable collaboration at school and work has never been so easy with Intel® processors, long battery life, and an optional HD IPS Touch panel.
Processing power
Get trusted processing power from an Intel® Celeron® processor that quickly launches apps, allows fast web browsing, and efficiently manages battery power.
Create an interactive learning experience with an optional Corning® Gorilla® Glass NBT™ IPS touch screen. This scratch-resistant screen can handle swiping and tapping, accidental bumps, or inadvertently closing the lid on a pencil.
Thinner and lighter
The HP Chromebook 11 is well suited for shared desk space in the classroom. At 18.4 mm thin and 2.51 lbs, the HP Chromebook 11 is now 10% thinner and 11% lighter than the previous version.
Inspire learning through collaboration
Collaborate easily on the HP Chromebook 11 with an optional IPS Touch panel. Optimize Google Hangouts and video collaboration with noise suppression for improved audio clarity.
HP Chromebook 11 G5 - 11.6" - Celeron N3050 - 4 GB RAM - 16 GB SSD - UK
Chromebook
Operating System
Google Chrome OS 64 - English
Intel Celeron N3050 / 1.6 GHz (2.1 GHz) / 2 MB Cache
4 GB LPDDR3
Storage
16 GB - eMMC SSD
Display
11.6" WLED 1366 x 768 / HD
Graphics
Intel HD Graphics
Input Device
ClickPad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
2-cell - up to 12.5 hours
Security
Trusted Platform Module (TPM 1.2) Security Chip
28.6 cm x 20.5 cm x 1.84 cm
1.137 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Chromebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
2.1 GHz
Number of Cores
Dual-Core
Cache
2 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1600 MHz
Storage
Main Storage
16 GB SSD - (eMMC)
Display
11.6" - TN
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Yes - HD
Video Resolutions
720p
Frame Rate
30 frames per second
Camera Features
HP TrueVision HD
Sound
Stereo speakers, two microphones
Codec
Realtek ALC5650
High Definition Audio
Input
Keyboard, ClickPad
Keyboard Layout
Multi-touch touchpad
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
2-cell lithium polymer
43.7 Wh
Run Time
Up to 12.5 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
2 x USB 3.1 Gen 1 (HP USB Boost) , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC, microSDXC UHS, microSDHC UHS)
Software
Software Included
Google Drive (100 GB Cloud Storage) (free for 2 years)
Security
Microphone with echo and noise-cancellation
Theft/Intrusion Protection
Power adapter
UL, VCCI, BSMI, GOST, FCC, WEEE, A-Tick, ICES, RoHS2
Localization
1.137 kg
ENERGY STAR Certified
Limited warranty - 1 year , Limited warranty - battery - 1 year
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Scroll to top
