BT.com
Wishlist
HP ADF MAINT ROLLER KIT HP CM6040/CM6030
Sorry but this product has been discontinued.
View used stock
Delivery
Standard Due date unavailable
HP printer maintenance kits ensure your HP printer remains in working condition and continues providing your workers with the highest print quality possible.
HP printer ADF maintenance kit
Printer ADF maintenance kit
Color LaserJet CM6030 MFP, CM6030f MFP, CM6040 MFP, CM6040f MFP
HP Color LaserJet CM6030 MFP, CM6030f MFP, CM6040 MFP, CM6040f MFP
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been opened but is in excellent condition
Ref: 88K8 029663
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£9.92
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
