BT.com
Wishlist
HP 65W Slim Adapter
Clearance
While Stocks Last
Delivery
Standard 3-5 working days
HP 65W Slim Adapter
AC power adapters from HP power your notebook and charge the internal battery simultaneously. These adapters provide you with the ability to power your notebook when away from the office or on the road. X3 Full compatibility depends on platform configuration. If 90W or higher is required note that the notebook will be powered when using basic applications and/or for charging. Performance delays may occur on specific platform configurations if lower than original power supply is used.
HP - power adapter - 65 Watt
Power adapter - external
220 g
Output Voltage
5 / 19.5 V
Power Capacity
65 Watt
12 cm x 5.8 cm x 1.7 cm
Compaq CQ58; Presario CQ57, CQ58; HP 43X; EliteBook 27XX; EliteBook Folio 9470; EliteBook Revolve 810 G1; Envy Pro; Folio 13; Folio 13; Pavilion dv6, dv7; Pavilion Sleekbook 14, 15; ProBook 430 G1, 450 G0, 45X G1, 45XX, 470 G0, 470 G1, 53XX, 64X G1, 65X G1; Spectre XT Pro; SPECTRE XT TouchSmart 15
Input Voltage Range
AC 100 - 240 V
Frequency Required
47 - 63 Hz
Output Voltage
5 / 19.5 V
Power Capacity
65 Watt
Over voltage protection, built-in USB charger
FCC Class B certified, CISPR 22 Class B, cUL, EN 60950, IEC950, NOM, UL 1950, EN55022 Class B
20 - 80%
12 cm
5.8 cm
1.7 cm
220 g
Compaq CQ58-200SG, CQ58-200SO, CQ58-201SG, CQ58-202SD, CQ58-202SS, CQ58-202TU, CQ58-203SD, CQ58-206SD, CQ58-206SL, CQ58-210SW, CQ58-215EW, CQ58-216SL, CQ58-217SL, CQ58-218SL, CQ58-219SL, CQ58-221SL, CQ58-222SL, CQ58-225EL, CQ58-225SL, CQ58-230SF, CQ58-237SF, CQ58-250EC, CQ58-250SC, CQ58-250SG, CQ58-251SH, CQ58-252SA, CQ58-252SS, CQ58-253SS, CQ58-260EA, CQ58-261EA, CQ58-270SO, CQ58-271SD, CQ58-276SD, CQ58-282SG, CQ58-295EG, CQ58-300SA, CQ58-300SB, CQ58-300SW, CQ58-301SL, CQ58-301SS, CQ58-301SW, CQ58-302SA, CQ58-302SP, CQ58-303SD, CQ58-303SO, CQ58-304SA, CQ58-305EW, CQ58-305SA, CQ58-306SD, CQ58-307SL, CQ58-311SL, CQ58-313ES, CQ58-313SS, CQ58-319EW, CQ58-320EW, CQ58-325SR, CQ58-330SF, CQ58-347SG, CQ58-350SG, CQ58-351EO, CQ58-351SC, CQ58-351SO, CQ58-353SO, CQ58-373SD, CQ58-392SG, CQ58-bf9WM, CQ58-d01SA, CQ58-d28SA, CQ58-d36SF, CQ58-d50SO, CQ58-d56SR , Compaq Presario CQ56-109WM, CQ57-386NR, CQ57-420SW, CQ57-430SW, CQ57-431SC, CQ57-441SL, CQ58-100SF, CQ58-100SH, CQ58-124SZ, CQ58-135SW, CQ58-145SW, CQ58-150SI, CQ58-150SL, CQ62-219WM , HP 2133 Mini-Note, 2140 Mini-Note, 3105m, 425, 430, 435, 500, 510, 530, 550, 610, 615, 625, 635 , HP EliteBook 2530p, 2540p, 2560p, 2730p, 2760p, 6930p, 8440p, 8460p, 8560p , HP EliteBook Folio 9470m , HP EliteBook Revolve 810 G1 Tablet , HP Envy Pro , HP Folio 13-1000ea, 13-1000eo, 13-1008tu, 13-1010ef, 13-1016tu, 13-1051nr , HP Folio 13 , HP Mini 5101, 5102, 5103 , HP Mobile Thin Client 4410t , HP Pavilion dv6-3019wm, dv7-4069wm , HP Pavilion Sleekbook 14-b002eo, 14-b023au, 14-b031tu, 15-b004eo, 15-b006eo , HP ProBook 430 G1, 4310s, 4320s, 4330s, 450 G0, 450 G1, 4510s, 4515s, 4520s, 4530s, 4540s, 455 G1, 470 G0, 470 G1, 5310m, 5320m, 5330m, 6360b, 640 G1, 6440b, 645 G1, 650 G1, 6540b, 655 G1 , HP Spectre XT Pro , HP SPECTRE XT TouchSmart 15-4000ew, 15-4095ca, 15-4101ef, 15-4110eo , HP Compaq 2230s, 2510p, 6530b, 6720s, 6730b, 6730s, 6735s , HP Compaq Mobile Thin Client 6720t
Scroll to top
