BT.com
Wishlist
HP 4GB DDR3 1066MHz SDRAM ECC Quad Rank
Delivery
Standard Due date unavailable
HP 4GB (1x4GB) Quad Rank x8 PC3-8500 (DDR3-1066) Registered CAS-7 Low Power Memory Kit
HPE Low Power kit - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1066 MHz ( PC3-8500 )
Latency Timings
CL7
Quad rank , registered
ProLiant BL2x220c G6, DL120 G6, DL160se G6, DL320 G6, DL370 G6, DL380 G6, ML330 G6, SL160z G6, SL170s G6, SL170z G6, SL2x170z G6, SL390s G7, WS460c G6; StorageWorks Network Storage Blade X1800; StorageWorks Network Storage System X1600, X1600 292, X1800, X1800 292, X3410, X3420, X3820
4 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL7
ECC
Compatible Slots
1 x memory - DIMM 240-pin
HPE ProLiant BL280c G6, BL2x220c G6, BL2x220c G6 Server A, BL2x220c G6 Server B, BL460c G6, BL490c G6, DL120 G6, DL120 G6 Performance, DL160 G6, DL160 G6 Special Server, DL160se G6, DL180 G6, DL180 G6 Special Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Entry, DL360 G6 Performance, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 Performance, ML150 G6, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML330 G6 Performance, ML330 G6 Special Server, ML350 G6, ML350 G6 Base, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL160z G6, SL170s G6 1U Left Half Width tray, SL170s G6 1U Right Half Width tray, SL170s G6 Base 1U Left Half Width tray, SL170s G6 Base 1U Right Half Width tray, SL170s G6 Entry 1U Left Half Width tray, SL170s G6 Entry 1U Right Half Width tray, SL170s G6 Performance 1U Left Half Width tray, SL170s G6 Performance 1U Right Half Width tray, SL170z G6, SL2x170z G6, SL390s G7, WS460c G6 Workstation Blade , HPE StorageWorks Network Storage Blade X1800sb , HPE StorageWorks Network Storage Gateway X3400, X3800, X3800sb , HPE StorageWorks Network Storage System X1400 2TB SATA Model, X1400 4TB SATA Model, X1600, X1600 12TB SATA Model, X1600 292GB SAS Model, X1600 5.4TB SAS Model, X1600 6TB SATA Model, X1800, X1800 2.4TB SAS Model, X1800 292GB SAS Model, X1800 3.6TB SAS Model, X1800 6TB SATA Model, X3410, X3420, X3820
Scroll to top
