BT.com
Wishlist
HP 250GB 7.2k HP 3.5" SATA HDD
Delivery
Standard Due date unavailable
Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HP SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HP SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one year warranty. All HP hard drives pass a rigorous qualification process, which certify that every HP drive is proven to perform in your HP ProLiant Server environments. Before final certification, all HP SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HP Systems Insight Manager.
HPE Entry - hard drive - 250 GB - SATA 3Gb/s
Hard drive - hot-swap
250 GB
3.5" x 1/3H
SATA 3Gb/s
Data Transfer Rate
300 MBps
Spindle Speed
7200 rpm
Native Command Queuing (NCQ)
11.1 cm x 18.4 cm x 2.6 cm
1 year warranty
HPE ProLiant DL120 G6, DL120 G7, DL160 G6, DL160se G6, DL165 G6, DL165 G7, DL180 G6, DL185 G5, DL2x170h G6, DL320 G6, DL370 G6, DL380 G6, DL380 G7, DL385 G5p, DL385 G6, DL385 G7, DL4x170h G6, ML110 G7, ML150 G6, ML310 G5p, ML330 G6, ML350 G6, ML370 G6; StorageWorks Network Storage System X1400, X1400 2TB, X1400 4TB, X1400 8TB, X1400 G2, X1500, X1500 4TB, X1500 8TB, X1500 G2, X1600 G2
250 GB
3.5" x 1/3H
SATA 3Gb/s
Bytes per Sector
512
11.1 cm
18.4 cm
2.6 cm
Performance
Drive Transfer Rate
300 MBps (external)
Seek Time
11 ms (average) / 21 ms (max)
Track-to-Track Seek Time
2 ms
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x hot-swap - 3.5" x 1/3H
1 year warranty
Service & Support Details
Limited warranty - parts and labour - 1 year
10 °C
35 °C
HPE ProLiant DL120 G6 (3.5"), DL120 G6 Base, DL120 G6 Performance, DL120 G7 (3.5"), DL120 G7 Base (3.5"), DL120 G7 Entry (3.5"), DL120 G7 Performance (3.5"), DL160 G6 (3.5"), DL160 G6 Special Server (3.5"), DL160se G6 (3.5"), DL165 G6, DL165 G7 (3.5"), DL165 G7 Base (3.5"), DL165 G7 Entry (3.5"), DL165 G7 Special Server (3.5"), DL180 G6 (3.5"), DL180 G6 Special Server (3.5"), DL185 G5, DL185 G5 Special Server, DL2x170h G6, DL320 G6 (3.5"), DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL370 G6 (3.5"), DL380 G6 (3.5"), DL380 G7 (3.5"), DL385 G5p (3.5"), DL385 G6 (3.5"), DL385 G7 (3.5"), DL4x170h G6, ML110 G7 (3.5"), ML110 G7 Performance, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML310 G5p, ML330 G6 (3.5"), ML330 G6 Base, ML330 G6 Entry, ML330 G6 Performance, ML330 G6 Special Server, ML350 G6 (3.5"), ML350 G6 Entry, ML350 G6 Special Server (3.5"), ML370 G6 (3.5") , HPE StorageWorks Network Storage System X1400, X1400 2TB SATA Model, X1400 4TB SATA Model, X1400 8TB SATA Model, X1400 G2, X1500, X1500 4TB SATA Model, X1500 8TB SATA Model, X1500 G2, X1600 G2
Scroll to top
