BT.com
Wishlist
HP 1TB SATA 3GB/S Hard Drive
Delivery
Standard Due date unavailable
Overview
SATA drives are our standard high bandwidth hard drive storage options; select models are also available with high performance 10K rpm rotation speeds. Storage capabilities range up to a massive 1000 GB.
• Improved protocol for enhanced data integrity
• Performance increase to up to 3 Gb/s maximum external (burst) data transfer rate
• Native Command Queuing allows the hard drive to have several write or read commands outstanding at the same time
HP - hard drive - 1 TB - SATA 3Gb/s
Hard drive - internal
1 TB
3.5" x 1/3H
SATA 3Gb/s
Data Transfer Rate
300 MBps
Buffer Size
32 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ)
8.89 cm x 10.17 cm x 2.54 cm
Workstation xw4600, xw6600, xw9400, z200, z400, z800; Workstation xw8600, z600
1 TB
3.5" x 1/3H
SATA 3Gb/s
Buffer Size
32 MB
8.89 cm
10.17 cm
2.54 cm
Performance
Drive Transfer Rate
300 MBps (external)
Seek Time
11 ms (average) / 21 ms (max)
Track-to-Track Seek Time
2 ms
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
5 °C
55 °C
HP Workstation xw4600, xw6600, xw9400, z200, z400, z800 , HPE Workstation xw8600, z600
Scroll to top
