BT.com
Wishlist
HP 1TB 6G SAS 7.2K 3.5IN DP HDD
Delivery
Standard 1-3 working days
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
HPE - hard drive - 1 TB - SAS 6Gb/s
Hard drive - hot-swap
1 TB
3.5"
SAS 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
11.1 cm x 18.9 cm x 2.6 cm
1 year warranty
ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G6, DL160 G6 Special Server, DL160se G6, DL165 G6, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Special Server, DL180 G6, DL180 G6 Special Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL370 G6, DL370 G6 Special Server, DL380 G6, DL380 G7, DL385 G6, DL385 G6 Performance, DL385 G7, ML110 G7, ML150 G6, ML150 G6 Base, ML150 G6 Performance, ML310 G5p, ML330 G6, ML330 G6 Base (3.5"), ML330 G6 Special Server (3.5"), ML350 G5 (3.5"), ML350 G5 Entry (3.5"), ML350 G6 (3.5"), ML350 G6 Base (3.5"), ML350 G6 Entry (3.5"), ML350 G6 Performance (3.5"), ML350 G6 Special Server (3.5")
1 TB
3.5"
SAS 6Gb/s
Bytes per Sector
512
11.1 cm
18.9 cm
2.6 cm
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
8.5 ms (average) / 16.2 ms (max)
Track-to-Track Seek Time
0.5 ms
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SAS
Compatible Bay
3.5"
Limited warranty - 1 year
10 °C
35 °C
HPE ProLiant DL120 G7 (3.5"), DL120 G7 Base (3.5"), DL120 G7 Entry (3.5"), DL120 G7 Performance (3.5"), DL160 G6 (3.5"), DL160 G6 Special Server (3.5"), DL160se G6 (3.5"), DL165 G6 (3.5"), DL165 G7 (3.5"), DL165 G7 Base (3.5"), DL165 G7 Entry (3.5"), DL165 G7 Special Server (3.5"), DL180 G6 (3.5"), DL180 G6 Special Server (3.5"), DL320 G6 (3.5"), DL320 G6 Entry (3.5"), DL320 G6 High Efficiency (3.5"), DL320 G6 Performance (3.5"), DL370 G6 (3.5"), DL370 G6 Special Server (3.5"), DL380 G6 (3.5"), DL380 G7 (3.5"), DL385 G6 (3.5"), DL385 G6 Performance (3.5"), DL385 G7 (3.5"), ML110 G7 (3.5"), ML150 G6 (3.5"), ML150 G6 Base (3.5"), ML150 G6 Performance (3.5"), ML310 G5p (3.5"), ML330 G6 (3.5"), ML330 G6 Base (3.5"), ML330 G6 Special Server (3.5"), ML350 G5 (3.5"), ML350 G5 Entry (3.5"), ML350 G6 (3.5"), ML350 G6 Base (3.5"), ML350 G6 Entry (3.5"), ML350 G6 Performance (3.5"), ML350 G6 Special Server (3.5")
Scroll to top
