BT.com
Wishlist
HP 150W Smart AC Adapter
Delivery
Standard Due date unavailable
Smart AC power adapters from HP power your notebook and charge the internal battery simultaneously. These adapters provide you with the ability to power your notebook when away from the office or on the road.
HP Smart - power adapter - 150 Watt
Power adapter - external
0.7 kg
English / United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
19 V
Power Capacity
150 Watt
16.9 cm x 7 cm x 4 cm
Compaq 610; HP 2510p, 2710p, 550, 6530b, 6535b, 6730b, 6730s, 6735b, 6735s, 6830s, 6910p, 8510p, 8710p; EliteBook 8530p, 8530w, 8540p, 8540w, 8730w; Mini 5101; ProBook 4710s, 6440b, 6445b, 6540b, 6545b; ZBook 15 Mobile Workstation, 15u G2 Mobile Workstation, 17 Mobile Workstation
Input Voltage
AC 100-240 V
Frequency Required
47 - 63 Hz
Output Voltage
19 V
Power Capacity
150 Watt
Power cable
MTBF
200,000 hours
Over voltage protection, automatic shut down
FCC Class B certified, CISPR 22 Class B, EN 60950, UL 1950
20 - 80%
16.9 cm
7 cm
4 cm
0.7 kg
Compaq 610 , HP 550 , HP EliteBook 8530p, 8530w, 8540p, 8540w, 8730w , HP Mini 5101 , HP ProBook 4710s, 6440b, 6445b, 6540b, 6545b , HP ZBook 15 Mobile Workstation, 15u G2 Mobile Workstation, 17 Mobile Workstation , HP Compaq 2510p, 2710p, 6530b, 6535b, 6730b, 6730s, 6735b, 6735s, 6830s, 6910p, 8510p, 8710p
Scroll to top
