Click to visit BT.com
BT.com
Wishlist
HP 146GB SAS 10K DUAL-PORT UNIV
Quicklinx: 5C76WS00
Mfr#: 418367-B21
HP 146GB 3G SAS 10K rpm SFF (2.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive
HPE Dual Port - hard drive - 146 GB - SAS
Hard drive - hot-swap
146 GB
2.5" SFF
SAS
Data Transfer Rate
300 MBps
Spindle Speed
10000 rpm
7 cm 1.5 cm
ProLiant BL25p G2, BL45p G2, BL460c, BL460c G6, BL465c, BL465c G5, BL465c G6, BL480c, BL680c G5, BL685c, BL685c G5, DL160 G6, DL160se G6, DL320 G6, DL360 G5, DL360 G6, DL360 G7, DL365, DL365 G5, DL370 G6, DL380 G5, DL380 G6, DL380 G7, DL385 G2, DL385 G5, DL385 G5p, DL385 G6, DL385 G7, DL580 G4, DL580 G5, DL585 G2, DL585 G5, DL585 G6, DL785 G5, DL785 G6, ML350 G5, ML350 G6, ML370 G5, ML370 G6, ML570 G4, WS460c G6
146 GB
2.5" SFF
SAS
7 cm
1.5 cm
Performance
Drive Transfer Rate
300 MBps (external)
Seek Time
4.1 ms (average) / 8 ms (max)
Track-to-Track Seek Time
0.6 ms
Spindle Speed
10000 rpm
Expansion & Connectivity
1 x SAS
Compatible Bays
1 x 2.5" SFF - hot-swap
10 °C
35 °C
HPE ProLiant BL25p G2 (2.5"), BL45p G2 (2.5"), BL460c G6 (2.5"), BL465c (2.5"), BL465c G5 (2.5"), BL465c G6 (2.5"), BL680c G5 (2.5"), BL685c (2.5"), BL685c G5 (2.5"), DL160 G6 (2.5"), DL160se G6 (2.5"), DL320 G6 (2.5"), DL360 G5 (2.5"), DL360 G5 High Efficiency (2.5"), DL360 G6 (2.5"), DL360 G6 Base (2.5"), DL360 G6 Efficiency (2.5"), DL360 G6 Entry (2.5"), DL360 G6 Performance (2.5"), DL360 G7 Base (2.5"), DL360 G7 Entry (2.5"), DL360 G7 Performance (2.5"), DL365 (2.5"), DL365 Base (2.5"), DL365 Entry (2.5"), DL365 G5 (2.5"), DL365 G5 Base (2.5"), DL365 G5 Entry (2.5"), DL365 G5 High Efficiency (2.5"), DL365 G5 Performance (2.5"), DL365 Performance (2.5"), DL370 G6 (2.5"), DL370 G6 Base (2.5"), DL370 G6 Performance (2.5"), DL380 G5 High Efficiency (2.5"), DL380 G6 (2.5"), DL380 G6 Base (2.5"), DL380 G6 Entry (2.5"), DL380 G6 High Efficiency (2.5"), DL380 G6 Performance (2.5"), DL380 G7 Base (2.5"), DL380 G7 Entry (2.5"), DL380 G7 Performance (2.5"), DL385 G2 (2.5"), DL385 G2 Base (2.5"), DL385 G2 Entry (2.5"), DL385 G2 High Performance (2.5"), DL385 G5 (2.5"), DL385 G5 Base (2.5"), DL385 G5 Entry (2.5"), DL385 G5 Performance (2.5"), DL385 G5p Base (2.5"), DL385 G5p High Performance (2.5"), DL385 G6 (2.5"), DL385 G6 Base (2.5"), DL385 G6 Entry (2.5"), DL385 G6 High Performance (2.5"), DL385 G7 (2.5"), DL385 G7 Base (2.5"), DL385 G7 Entry (2.5"), DL385 G7 Performance (2.5"), DL580 G4 High Performance (2.5"), DL580 G5 (2.5"), DL580 G5 Base (2.5"), DL580 G5 High Performance (2.5"), DL585 G5 (2.5"), DL585 G6 (2.5"), DL585 G6 Base (2.5"), DL785 G5 (2.5"), DL785 G6 (2.5"), DL785 G6 Base (2.5"), DL785 G6 Performance (2.5"), ML350 G5 Base (2.5"), ML350 G6 (2.5"), ML350 G6 Base (2.5"), ML350 G6 Performance (2.5"), ML370 G5 (2.5"), ML370 G5 Base (2.5"), ML370 G5 Entry (2.5"), ML370 G5 High Performance (2.5"), ML370 G6 (2.5"), ML370 G6 Base (2.5"), ML370 G6 Entry (2.5"), WS460c G6 Workstation Blade (2.5")
