BT.com
Wishlist
HP 1.83M 10A C13 UK Power Cord
Delivery
Standard 3-5 working days
Marketing description is not available.
HPE power cable - 1.83 m
Power cable
Length
1.83 m
Hong Kong, Singapore, United Kingdom
Connector
Power BS 1363A - male
Connector (Second End)
Power IEC 60320 C13 - male
Rated Voltage
AC 250 V
HPE MSL2024, MSL4048; 1/8 G2 Tape Autoloader; Apollo 4510 Gen9; ProLiant DL360 G5, DL360 G6, DL360 G7, DL365 G5, DL370 G6, DL380 G5, DL380 G6, DL380 G7, DL380p Gen8, DL560 Gen8, DL580 G7, DL980 G7, ML110 G5, ML115 G5, ML370 G6, SL165s G7; StorageWorks 300, 61XX, 65XX, 68XX, MSL6030, MSL6052, MSL6060
Power cable
Rated Voltage
AC 250 V
Length
1.83 m
Connector
HPE MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL4048 Ultrium 1760 , HPE 1/8 G2 Tape Autoloader Ultrium 1760 , HPE Apollo 4510 Gen9 , HPE ProLiant DL360 G5 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL370 G6, DL370 G6 Base, DL370 G6 Performance, DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Special Server, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL980 G7, ML110 G5, ML115 G5, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL165s G7 , HPE StorageWorks 300 Virtual Library System Gateway Base Unit, 6105 Virtual Library System, 6109 Virtual Library System, 6510 Virtual Library System, 6518 Virtual Library System, 6840 Virtual Library System, 6870 Virtual Library System, MSL6026, MSL6030, MSL6030 Ultrium 460, MSL6030 Ultrium 960, MSL6052, MSL6060, MSL6060 Ultrium 460, MSL6060 Ultrium 960
Scroll to top
