BT.com
Wishlist
HP - Solid state drive - 512 GB - internal - 2.5" SFF
Delivery
Standard Due date unavailable
Get a storage solution that significantly improves boot-up, shut down, and application loading times as well as overall responsiveness. Since SSDs have no moving parts, your storage performance is no longer bound by mechanical barriers.
Get better application and operating system performance with a solid state drive because it does not need to spin up or mechanically seek files like a conventional hard disk drive.
Work quieter with a drive that emits less noise than a spinning hard drive. The lack of moving parts also makes SSDs sturdier and more resistant to shock and vibrations than HDDs.
Help conserve power with reduced cooling requirements, which allow the workstation to maintain lower fan speeds.
HP - solid state drive - 512 GB - SATA 6Gb/s
Solid state drive - internal
512 GB
2.5" SFF (in 3.5" carrier)
SATA 6Gb/s
Data Transfer Rate
600 MBps
6.36 cm 7 mm
Pricing Type
Promo
1 year warranty
Workstation Z1, Z1 G3, Z220, Z4 G4, Z420, Z640, Z820
512 GB
2.5" SFF
SATA 6Gb/s
6.36 cm
7 mm
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
500 MBps (read) / 260 MBps (write)
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" SFF or 3.5" (with included bay adapter)
3.5-inch bay adapter
4 x Serial ATA cable
RoHS
Pricing Type
Promo
Limited warranty - 1 year
70 °C
HP Workstation Z1, Z1 G3, Z220, Z4 G4, Z420, Z640, Z820
Scroll to top
