BT.com
Wishlist
HP - DDR4 - 4 GB - DIMM 288-pin - 2400 MHz / PC4-19200
HP - DDR4 - 4 GB - DIMM 288-pin -...
£190.09
35 in stock
£190.09
Add to wishlist
Delivery
Standard 1-3 working days
Boost the capabilities of your HP Workstation and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Registered
Voltage
1.2 V
HP 852260-001, HP T9V38AT
Workstation Z440, Z640, Z840
4 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
ECC
Registered
Chips Organization
512 x 8
Voltage
1.2 V
HP Workstation Z440, Z640, Z840
Scroll to top
