BT.com
Wishlist
HP - DDR4 - 4 GB - DIMM 288-pin - 2133 MHz / PC4-17000
HP - DDR4 - 4 GB - DIMM 288-pin -...
£263.12
13 in stock
£263.12
Add to wishlist
Delivery
Standard 1-3 working days
Boost the capabilities of your HP Workstation and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Unbuffered
Voltage
1.2 V
HP N0H86AT, HP 840820-001
Workstation Z238, Z240
4 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Unbuffered
Chips Organization
512 x 8
Voltage
1.2 V
HP Workstation Z238, Z240
Scroll to top
