BT.com
Wishlist
HP - DDR4 - 16 GB - DIMM 288-pin - 2133 MHz / PC4-17000
HP - DDR4 - 16 GB - DIMM 288-pin -...
£350.98
Hurry, only 1 left in stock!
£350.98
Add to wishlist
Delivery
Standard 1-3 working days
Boost the capabilities of your HP Workstation and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
Flexible, fast scalability
Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast memory that you can scale to meet your exact requirements.
HP-tested.
Ensure that all of your memory characteristics match by upgrading with HP-branded memory that’s been tested for seamless system-level integration with HP Workstations.
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Unbuffered
Voltage
1.2 V
HP T0E52AT, HP 840819-001
Workstation Z238, Z240
16 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
Non-ECC
Unbuffered
Chips Organization
1024 x 8
Voltage
1.2 V
HP Workstation Z238, Z240
Scroll to top
