BT.com
Wishlist
HP - DDR4 - 16 GB - DIMM 288-pin - 2133 MHz / PC4-17000
HP - DDR4 - 16 GB - DIMM 288-pin -...
£411.49
£411.49
Add to wishlist
Delivery
Standard Due date unavailable
Boost the capabilities of your HP Workstation with registered DDR4 memory from HP. Get high reliability and cost savings on high-capacity modules vs. unregistered memory.
Maximise the newest processors.
Keep the newest multi-core processors performing at their peak with fast memory. Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between several open applications.
Benefit from integrated ECC.
Help avoid errors that can corrupt data sets and introduce system issues when you select ECC memory, which includes Error Checking and Correcting technology to correct single-bit memory errors.
Get HP-tested reliability.
Ensure all of your memory characteristics match by upgrading with HP-branded memory that’s been tested at the component level and to ensure seamless system-level integration with HP products.
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Dual rank, registered
Voltage
1.2 V
HP J9P83AT, HP 790111-001
Pricing Type
Promo
Workstation Z440, Z640, Z840
16 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Voltage
1.2 V
Pricing Type
Promo
HP Workstation Z440, Z640, Z840
Scroll to top
