BT.com
Wishlist
Hive Active Light - Screwfit (E27) 9W Warm White
Hive Active Light - Screwfit (E27)...
Free delivery
£19.00
Free delivery
14 in stock
£19.00
Add to wishlist
Delivery
Standard 3-5 working days
Hive Active Light Dimmable - Screw fitting
Down for Sunday night, up for Monday morning: set our dimmable smart bulb to the level you want with a tap of the Hive app.
  • Just replace your existing light bulb with a Hive Active Light and pair with your Hive Hub.
  • Set schedules and pick your brightness to match the moment.
  • Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Make time in the morning
Turn your lights off from your phone after you’ve left for work.
Keep the bogeyman at bay
Little ones afraid of the dark? Connect your Hive Active Light to a Hive Sensor with Hive actions, so as soon as they’re up, the landing light is too.
Movie nights done right
Lower the lights without leaving your sofa using your Hive app.
Hive Active Light - LED light bulb
Other bundles
£19.00
Hive Active Light - 3 Pack
Save £8.00
£49.01
£19.00
Google Home Mini - Chalk
Save £5.00
£63.00
£19.00
Google Home Mini - Charcoal
Save £5.00
£63.00
Scroll to top
