BT.com
Wishlist
Hitachi Euroscreen Connect electric screen in 1:1 square format
Hitachi Euroscreen Connect electric...
£405.20
£405.20
Add to wishlist
Delivery
Standard Due date unavailable
Connect Electric is a basic compact screen which is very easy to install. It can be mounted either on the wall or in the ceiling and is attached to the wall/ceiling with one screw at each end of the case. The screen can be operated by an in-line switch, an IR remote control or automatically by an AutoLink connected to the projector.
Euroscreen Connect Electric Square Format - projection screen - 133 in (339 cm)
Projection screen - motorised - 220 V
Placing / Mounting
Ceiling mountable, wall mountable
Projection Screen Image Diagonal Size
133 in (339 cm)
Projection Image Size
240 cm x 240 cm
Aspect Ratio
1:1
Screen Surface
Arctiq
249 cm
11.8 kg
English
Placing / Mounting
Image Diagonal Size
133 in (339 cm)
Image Width
240 cm
Image Height
240 cm
Screen Surface
Arctiq
Aspect Ratio
1:1
Gain
1.0x
Viewing Angle
180°
Screen Thickness
0.37 mm
Mildew resistant, fire resistant, washable, black backing
249 cm
11.8 kg
English
Remote control
Scroll to top
