BT.com
Wishlist
Hitachi CP-D10 Short-throw XGA Project
Delivery
Standard Due date unavailable
2000 lumens project a clear image in any classroom or conference room. The projector can output audio in stand-by mode, allowing you to listen to external speakers via the projector's audio output. Keeping the projector in standby mode saves lamp life. Hybrid filter provides a lower cost of ownership requiring less frequent maintenance schedules. Line templates in the projector menu can help when writing on a whiteboard.
Hitachi CP-D10 LCD projector
LCD projector
Built-in Devices
Speaker
Brightness
2000 lumens
Contrast Ratio
400:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
16.7 million colours
Bulb type
UHB 180 Watt
Bulb life cycle
Up to 3000 hour(s) / up to 4000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Output
RGB
Speakers
Speaker(s) - integrated
AC 120/230 V
250 Watt
33.3 cm x 30.2 cm x 10.4 cm
3.5 kg
LCD projector
Built-in Devices
Speaker
Projector
Brightness
2000 lumens
Contrast Ratio
400:1
Throw Ratio
0.60:1
Digital Zoom Factor
1.3x
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Display Format
786,432 pixels (1,024 x 768) x 3
Colour Support
Max Sync Rate (V x H)
120 Hz x 106 kHz
Bulb type
UHB 180 Watt
Bulb life cycle
Blackboard Mode, Closed Caption, 16:9 aspect ratio support, Whiteboard Mode
Lens
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-5/ +5
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Input Device
External
2 x audio line-in - mini-phone stereo 3.5 mm , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA input - 15 pin D-Sub (DB-15) , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - RCA x 2 , 1 x audio line-in - RCA x 2 , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management)
Wireless remote control
Security Features
Security label
UL, cUL, FCC, RoHS
Nominal Voltage
AC 120/230 V
250 Watt
33.3 cm
30.2 cm
10.4 cm
3.5 kg
5 °C
35 °C
Sound Emission
37 dB
29 dB
Accessories
Hitachi Replacement lamp for CP-D10
Quicklinx: 6N2L | In Stock
£212.66
Scroll to top
