BT.com
Wishlist
Hitachi CP-AX2505 Ultra Short Throw LCD Projector
Hitachi CP-AX2505 Ultra Short Throw...
£720.46
More than 50 in stock
£720.46
Add to wishlist
Delivery
Standard 1-3 working days
Hitachi's CP-AX2505 ultra short throw LCD projector is ideally suited for producing large images in limited spaces. It provides vibrant image quality with cost-effective operation. A suite of advanced features normally found only on higher end models includes 2 HDMI ports, High Dynamic Contrast Range (HDCR), and Hitachi's original technology Accentualizer that allows the projected image to appear more real by enhancing sharpness, gloss and shade. Along with its light weight and compact design, the CP-AX2505 offers Hitachi's most appreciated installation feature, "Perfect Fit", allowing time saving and ease of installation. As with all Hitachi projectors, you can expect vibrant image quality, cost-efficient operation, and long-lasting reliability. Plus, Hitachi's Intelligent Eco and Saver Modes with ImageCare combines optimal picture performance with energy savings for a lower total cost of ownership.
Hitachi CP-AX2505 3LCD projector
3LCD projector
Built-in Devices
Speaker
Brightness
2700 lumens
Contrast Ratio
10000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
16.7 million colours
Bulb type
225 Watt
Bulb life cycle
Up to 5000 hour(s) / up to 10000 hour(s) (economic mode)
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43), LAN
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i
Speakers
Speaker(s) - integrated
330 Watt
37.6 cm x 36.1 cm x 13.7 cm
4.26 kg
3 years warranty
3LCD projector
Built-in Devices
Speaker
Ethernet
Projector
Brightness
2700 lumens
Contrast Ratio
10000:1
Image Size
152 cm - 254 cm
Projection Distance
0.38 m - 0.66 m
Throw Ratio
0.2 - 0.3:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 106 kHz
Bulb type
225 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Closed Caption, 3LCD Technology, 16:9 aspect ratio support, input source naming, 16:10 aspect ratio support, AMX Device Discovery, Perfect Fit 2, Template Function, PJMessenger, ImageCare Technology, Cloning Function, Intelligent Eco, High Dynamic Contrast Range (HDCR), Tabletop Presentation, Projector Quick Connection
Lens
Lens Aperture
F/1.8
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-5/ +5
Horizontal Keystone Correction
-5/ +5
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
2 x HDMI - 19 pin HDMI Type A , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone input - mini-phone mono 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 2 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management)
Cable cover, 2 x AA batteries, wireless remote control, adapter cover
1 x VGA cable
Security Features
PIN code
FCC Class B certified, cUL, FCC Part 15 B, UL 60950-1
Power Source
AC
Nominal Voltage
330 Watt
Software Included
Drivers & Utilities
37.6 cm
36.1 cm
13.7 cm
4.26 kg
Limited warranty - parts and labour - 3 years
Scroll to top
