BT.com
Wishlist
Hitachi 5200 LumensWUXGA Resolution LCD Technology Projector
Delivery
Standard Due date unavailable
Easy installation - selection of wide zoom bayonet lenses, wide vertical and horizontal lens shift and control code emulation guarantees hassle-free installation and replacement of old installation projectors. Easy way to a big picture - up to 4K interface, HDMI-out signal loop through, built-in signal splitter and edge blending capability enables large presentation pictures without any external devices. PiP function allows additional sources to be displayed.
Free Download of Multi-Display Management Software - with NaViSet Administrator 2 you can manage all your connected display devices from a centralized location. Very low cost of ownership - long lamp life of up to 4000 hours, inorganic long life panels, maintenance free filters and standby power of just 0.15W. Widest application support - portrait mode projection, 360 degree free tilt installation, unique geometric adjustment and 3D support offers unrivaled installation capability.
Rich connectivity - including HDBaseT, the world's first HDMI-out interface, 2xHDMI and DisplayPort technology guarantees outstanding connectivity. Perfect Image quality - high brightness, up to 4K input signal and unique picture and color processing technology based on the latest NEC scaler chip achieves outstanding picture quality.
NEC PA522U LCD projector - 3D
LCD projector - High Definition 1080p
3D Capable
Brightness
5200 ANSI lumens
Contrast Ratio
5000:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Lens
No lens
Lens Shift Direction
Horizontal, vertical
Bulb type
UHP 330 Watt
Bulb life cycle
Up to 3000 hour(s) / up to 4000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
Video Modes
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 576/50i, 480/50i
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
460 Watt
49.9 cm x 35.9 cm x 14.2 cm
8.4 kg
3 years warranty
LCD projector - HD 1080p
3D Capable
Projector
Brightness
5200 ANSI lumens
Contrast Ratio
5000:1
Image Size
76 cm - 1270 cm
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
120 Hz x 153 kHz
Bulb type
UHP 330 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Picture in picture, 3D Reform technology, Micro Lens Array (MLA) Technology, Edge blending, wall colour correction, Side-by-Side, PJlink, Crestron RoomView, Intelligent Power Management, DICOM Simulation Mode, Direct Power Off, Geometric Correction, Cinema Quality Picture (CQP) Processing, Multi-Screen compensation mode
Lens
No lens
Focus Type
Manual
Zoom Type
Manual
Keystone Correction Direction
Vertical Keystone Correction
-40 / +40
Horizontal Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, composite video, S-Video, RGB
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
5 x composite / component video / S-Video / RGB input - BNC , 1 x VGA input - 15 pin D-Sub (DB-15) , 1 x DisplayPort input - 20 pin DisplayPort , 1 x HDBaseT - RJ-45 , 2 x HDMI input - 19 pin HDMI Type A , 1 x HDMI output - 19 pin HDMI Type A , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB 2.0 - 4 pin USB Type A , 1 x 3D Sync out - 3 PIN mini-DIN , 1 x remote control - mini-phone stereo 3.5 mm
Wireless remote control
Security Features
Security lock slot (cable lock sold separately), password protection
TUV GS, RoHS, ERP
Nominal Voltage
460 Watt
Power Consumption Stand by
0.16 Watt
49.9 cm
35.9 cm
14.2 cm
8.4 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
Sound Emission
39 dB
33 dB
Scroll to top
