BT.com
Wishlist
HGST Travelstar Z5K500 HTS545032A7E380 Hard Drive 320GB SATA 3Gb/s
Delivery
Standard Due date unavailable
Travelstar Z5K500 is the 5400 RPM 2.5-inch hard drive from Hitachi, with high capacity, and the Advanced Format drive. Advanced Format increases the physical sector size on HDDs from 512 bytes to 4,096 bytes, which improves drive capacities and error correction capabilities. The Z5K500 carries the EcoTrac classification due to its low-power consumption and eco-friendly, halogen-free production. Travelstar Z5K500 delivers the right balance of capacity, power-management and design flexibility to meet the needs of mobile applications.
HGST Travelstar Z5K500 HTS545032A7E380 - hard drive - 320 GB - SATA 3Gb/s
Hard drive - internal
320 GB
2.5"
SATA 3Gb/s
Data Transfer Rate
300 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Load/unload technology, TrueTrack servo technology
70 mm x 100 mm x 7 mm
95 g
Microsoft Certification
Compatible with Windows 7
320 GB
2.5"
SATA 3Gb/s
Buffer Size
8 MB
Bytes per Sector
512
70 mm
100 mm
7 mm
95 g
Performance
Drive Transfer Rate
300 MBps (external)
Internal Data Rate
124 MBps
Seek Time
13 ms (average) / 25 ms (max)
Track-to-Track Seek Time
1 ms
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Halogen-free
60 °C
Shock Tolerance
400 g @ 2ms half-sine pulse (operating) / 1000 g @ 1ms half-sine pulse (non-operating)
Accessories
£19.66
£7.48
£10.18
StarTech.com Dual-bay 2.5" Drive Enclosure
Quicklinx: B90V | In Stock
£67.62
Scroll to top
