BT.com
Wishlist
HGST Hitachi Ultrastar 7K4000 HUS724040ALA640 Hard Drive 4TB SATA 6Gb/s
HGST Hitachi Ultrastar 7K4000...
£223.80
£223.80
Add to wishlist
Delivery
Standard Due date unavailable
Ultrastar 7K4000 represents the sixth-generation HGST 5-platter design, which has been field proven by top server and storage OEMs and Internet giants. Engineered for the highest quality, the Ultrastar 7K4000 is put through grueling design tests during development and must pass stringent ongoing reliability testing during manufacturing. Ultrastar 7K4000 delivers by reducing downtime, eliminating service calls and minimizing TCO.
Operating at 7200 RPM, Ultrastar 7K4000 offers better overall performance than slower RPM capacity-oriented drives, and does so at impressively low power-consumption rates. The Ultrastar 7K4000 can help data centers achieve lower AC power and HVAC requirements. With five advanced power Management modes, the 7K4000 achieves a 59% reduction in watts during low RPM idle mode, and uses less than 1 W during standby/sleep modes, freeing up precious headroom for growing enterprise needs.
HGST Ultrastar 7K4000 HUS724040ALA640 - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Rotational Vibration Safeguard (RVS), Thermal Flyheight Control (TFC), Enhanced Availability (EA) for 24x7 accessto data, Advanced Format technology, Dual Stage Actuator (DSA), S.M.A.R.T.
10.16 cm x 14.7 cm x 2.61 cm
0.69 kg
Microsoft Certification
Compatible with Windows 7
5 years warranty
4 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
512
10.16 cm
14.7 cm
2.61 cm
0.69 kg
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
181 MBps
Seek Time
8 ms (average)
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^15
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
11.4 Watt (active) , 5.7 Watt (idle)
5 years warranty
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance
70 g @ 2ms half-sine pulse (operating) / 300 g @ 1ms half-sine pulse (non-operating)
Vibration Tolerance
0.67 g @ 5-500 Hz (operating)
Scroll to top
