BT.com
Wishlist
HGST 500GB Touro Mobile 2.5" USB 3.0 Portable Hard Drive
Delivery
Standard Due date unavailable
500GB Touro Mobile USB 3.0 Portable Hard Drive
  • Portable storage for all your digital files
  • Smooth, textured body for solid good looks
  • Preformatted for PCs, easily reformatted for Macs
  • USB powered
  • 2.5 inch External Hard Disk Drive
  • Sleek mobile design is perfect for the style-conscious consumer
  • USB 3.0 interface delivers fast transfer speeds - Compatible with USB 2.0.
Touro™ Mobile external drive provides portable storage for all your photos, movies, music and documents. With plug and play simplicity, Touro Mobile comes with all the quality and reliability you expect from HGST. HGST develops advanced hard disk drives, enterprise-class solid state drives, and innovative external storage solutions and services to store, preserve and manage the world's most valued data.
  • Interface:USB 3.0 compliant, USB 2.0 compatible
  • Connector: Combination USB 3.0, 9-pin Micro-B socket/USB 2.0, 5-pin Micro-B socket
  • Data Transfer Rate: USB 3.0: up to 5 Gbit/sec / USB 2.0: up to 480 Mbit/sec
  • Power: USB bus-powered
  • Operating Temp: 41° - 95°F (5° - 35°C)
  • Relative Humidity: 20-80% non-condensing
  • Operating Systems: Windows XP®, Windows Vista®, Windows 7™ and Mac OS® X (10.5 or newer)
  • Web Browsers: Internet Explorer (7 or newer), Mac Safari (4 or newer)
  • Dimensions: 80mm x 126mm x 15mm
  • Weight: 155gm
  • Windows® users: Computer system running with Windows® XP, Windows® Vista, or Windows 7™ and an available USB 3.0 or USB 2.0 port
  • Mac® users: Computer system running with Mac OS® 10.5 or newer and an available USB 3.0 or USB 2.0 port / Intel® processor-based Macs only
Includes
  • Touro Mobile portable hard drive
    • USB 3.0 cable (backward compatible with USB 2.0)
  • Quick Start Guide
  • 2-year limited warranty
Hard drive - external (portable)
500 GB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Bus Powered by USB
Power Source
USB bus
Enclosure Colour
8 cm x 12.6 cm x 1.5 cm
155 g
EMEA
2 years warranty
500 GB
2.5"
USB 3.0
Bus Powered by USB
8 cm
12.6 cm
1.5 cm
155 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type B
Compatible Bay
2.5"
Power Source
USB bus
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
1 x USB 3.0 cable
Enclosure Colour
EMEA
5 °C
35 °C
20 - 80% (non-condensing)
Resources
The following resources are available for the HGST 500GB Touro Mobile 2.5" USB 3.0 Portable Hard Drive
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* HGST 500GB Touro Mobile 2.5" USB 3.0 Portable Hard Drive
Reviewed by RSL on 26/09/2013
For me the fact this drive does not come with 'free' software that I do not want is an advantage. Lets face it free software isn't free, the cost is just hidden. So I've not paid for software I don't want and I have not had to delete anything. First impressions are the disk very light and performs well. In comparison to other external drives I have (Iomega and Lacie) this one is practically silent in operation. The reason why my overall product rating is a 4 not a 5 is because the USB cable is a Micro B 3.0 so I have yet another cable type to contend with and the supplied cable, at only 18 inches in length, is too short. I've only had the product one day so am unable to give any feedback on reliability.
Scroll to top
