Click to visit BT.com
BT.com
Wishlist
HGST 4TB DeskStar 7K4000 SATA 6Gb/s 7200RPM 64MB 3.5" Hard Drive
Quicklinx: 8203WS00
Mfr#: 0S03356
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 4TB
Spin Speed (rpm): 7200rpm
£124.51
Essential accessories
The Hitachi Deskstar internal hard drive kit delivers colossal add-on storage and award-winning performance with an industry-standard interface. Choose either a high-performing 7200 RPM or low-power CoolSpin models in a standard 3.5-inch desktop form factor. No additional hardware is required to overcome the 2.2 TB limitations of Windows systems with 4 TB and 3 TB kits as they ship with Hitachi GPT Disk Manager.
CoolSpin technology provides excellent power utilization and heat emission, as well as quiet acoustics.
The Hitachi Deskstar hard drive features a robust mechanical design that exceeds the industry standard for quality and reliability. Through a patterned ramp load/unload design, the risk of shock damage is minimized by eliminating direct contact between the heads and disks, reducing wear and heat while improving the overall drive reliability and power efficiency.
The Deskstar™ 7K4000 offers the industry's highest hard drive capacity at an enormous four terabytes of storage with 7200 RPM performance in a standard 3.5-inch form factor.
This drive uses Advanced Format, which increases the sector size on HDDs from 512 bytes to 4096 (4K) bytes, thereby increasing capacities and improving error correcting capabilities.
Consult the Hitachi Advanced Format Technology Brief for more information. The 7K4000 also boasts a 6Gb/s SATA interface and 64MB cache buffer to balance performance and capacity.
The Deskstar 7K4000 is designed to help manufacturers deliver high-performance, high-capacity, power-efficient systems. Manufacturers planning to use the 4TB drive in systems should consult the Hitachi High Capacity Technology Brief.
  • Colossal add-on storage for your PC or Mac
  • Hitachi GPT Disk Manager to overcome the 2.2 TB limitation of Windows systems
  • 3.5-inch Desktop SATA interface
  • Green, eco-friendly technology
  • Exceeds the industry standard for quality and reliability
HGST IDK Deskstar H3IK40003272SE - hard drive - 4 TB
Hard drive - internal
4 TB
3.5"
Spindle Speed
7200 rpm
Load/unload technology
EMEA
3 years warranty
4 TB
3.5"
Performance
Spindle Speed
7200 rpm
Expansion & Connectivity
Compatible Bays
1 x internal - 3.5"
EMEA
3 years warranty
Service & Support Details
Limited warranty - 3 years
HGST 4TB DeskStar 7K4000 SATA 6Gb/s 7200RPM 64MB 3.5 Bundle deal on HGST 4TB DeskStar 7K4000 SATA 6Gb/s 7200RPM 64MB 3.5" Hard Drive
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£144.04
saving £8.68
Cables (1)
Cables
Including:
£126.29
saving £1.78
Options (2)
Including:
£126.31
saving £1.80
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£134.50
Form Factor: 3.5"
Type: Hard drive
Capacity: 4TB
Brand: HGST
Price Range Inc VAT: 100 - 150
