BT.com
Wishlist
HGST 1TB Travelstar SATA 6GB/s 5400RPM 8MB 9.5mm Hard Drive
HGST 1TB Travelstar SATA 6GB/s...
£41.14
£41.14
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Friday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Travelstar 5K1000 is a 5400 RPM, 500GB/platter, 2.5-inch hard drive. This standard 9.5mm, two-disk design, intended for use in notebook PCs, external storage, gaming consoles and other mobile applications, leverages advanced format, which increases the physical sector size on hard drives from 512 bytes to 4096 (4K) bytes to increase drive capacities and improve error correction capabilities.
HGST Travelstar 5K1000 HTS541010A9E680 - hard drive - 1 TB
Hard drive - internal
1 TB
2.5" x 1/8H
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
TrueTrack servo technology, Thermal Flyheight Control (TFC), Advanced Format technology
70 mm x 100 mm x 9.5 mm
102 g
Microsoft Certification
Compatible with Windows 7
1 TB
2.5" x 1/8H
Buffer Size
8 MB
Bytes per Sector
512
70 mm
100 mm
9.5 mm
102 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
125 MBps
Seek Time
12 ms (average) / 20 ms (max)
Track-to-Track Seek Time
1 ms
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
Halogen-free
60 °C
Shock Tolerance
225 g @ 1ms half-sine pulse (operating) / 1000 g @ 1ms half-sine pulse (non-operating)
Cables - Cables
HGST 1TB Travelstar SATA 6GB/s 5400RPM 8MB 9.5mm Hard...
£41.14
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.19
£44.33
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Bit noisy under load
Reviewed by R Cunningham on 04/08/2015
Purchased to replace failing WD laptop hard drive which had failed after approx. two years of almost no use (failure found to have been due to it constantly parking the heads every few seconds).
I haven't been using this hard drive for very long but performance seems on par with the previous hard drive.
I would just like to point out to any potential purchaser that this drive does NOT have AAM (Automatic Acoustic Management) which I hadn't seen mention of in any review and I was somewhat perturbed to discover. It does have APM (Advanced Power Management) so I've seen mention it may be possible to reduced the noise via this but I haven't tested for myself yet.
The noise is not exceptionally loud but is just noticeable even when the laptop fan is on fully, so it's definitely there and could well be annoying if your are trying to create a silent system setup.
If it had AAM / hadn't been so noisy it would be an easy 5 stars.
Scroll to top
